had a simple utility_meter config:
utility_meter:
watermeter_quarter_hourly:
# name: Verbruik per kwartier
source: sensor.watermeter_stand
cycle: quarter-hourly
watermeter_hourly:
# name: Verbruik per uur
cycle: hourly
and had customized these entities friendly_names via
homeassistant:
customize:
sensor.watermeter_hourly:
friendly_name: Verbruik per uur
which resulted in the entity_id sensor.watermeter_hourly
and set the friendly_name according to the customize.
then I noticed we could set Utility Meter - Home Assistant to
The friendly name to use in the GUI.
ippon restart all my entities had vanished:
and states inspection reveals not only did the name: change the friendly name in the GUI, it also changed all entity_id’s…
even though the config is:
utility_meter:
watermeter_quarter_hourly: # <--- entity_id no longer respected ??
name: Verbruik per kwartier # <-- sets not only friendly_name, but also entity_id ?
watermeter_hourly:
cycle: hourly
this seems a bug, and raised an issue Setting name: in utility_meter affects entity_id too · Issue #67691 · home-assistant/core · GitHub
