Setting slider to manual volume change
I have set up a slider to contro volume of myAVR with a slider. How do I get the slider to update if the volume is adjusted manually. In other words trigger an automation to set the value of the slider. My config for the slider control is as follows:
media_player:
platform: denon_avr
host: 192.168.1.101
input_slider:
denon_volume:
initial: 0.3
min: 0
max: 1
step: 0.01
automation 4:
  • alias: Denon - Adjust Volume
    platform: state
    entity_id: input_slider.denon_volume
    • service: media_player.volume_set
      data_template:
      entity_id: media_player.denon_avr
      volume_level: ‘{{ trigger.to_state.state }}’
Please post your code properly so that any issues with formatting can be ruled out.
To post code with formatting intact, highlight the code blocks and then press the preformatted text option button as indicated in the image below.
Thanks…completely new to this. Formatted code below. As I said, the code is working fine. It sthe next step of feeding back information to the slider where I don’t know where to begin.
media_player:
platform: denon_avr
host: 192.168.1.101
media_player:
  platform: denon_avr
  host: 192.168.1.101
input_slider:
  denon_volume:
    initial: 0.3
    min: 0
    max: 1
    step: 0.01
automation 4:
  - alias: Denon - Adjust Volume
      platform: state
      - service: media_player.volume_set
        data_template:
          volume_level: '{{ trigger.to_state.state }}'
Any luck implementing the volume feedback to slider ?
Exactly trying to do this, but unable to find a suitable trigger.
- alias: Music Volume Select
    platform: state
    entity_id: media_player.music
    service: input_slider.select_value
    data_template:
      entity_id: input_slider.music
      value: >
        {{ states.media_player.music.attributes.volume_level }}
Thanks, this works!
Has anyone had any luck getting this working with Sonos?
I have set it up but it will only update the volume at 1… and go back to 0, nothing in between (e.g. 0.1 - 0.3 etc where sonos needs the volume set)
volume:
  initial: .2
  min: 0
  max: 1
  step: 0.01
- alias: Kitchen Sonos Volume Slider
    platform: state
    entity_id: input_slider.volume
      data_template:
        entity_id: media_player.kitchen
        volume_level: '{{ trigger.to_state.state | int }}'
I also tried it the way mentioned above but that didn’t work at all :frowning: for me.
- alias: Kitchen Music Volume Select
    platform: state
    data_template:
      value: >
        {{ states.media_player.kitchen.attributes.volume_level }}
input slider:
music:
  initial: .2
  min: 0
  max: 1
  step: 0.01
Hi @Stewface
I think you use the wrong trigger for your automation.
Your Automation must run, when the Volume is changed.
I’m using for my denon:
- alias: Denon Volume
    platform: state
    entity_id: input_slider.volume_setpoint
      data_template:
        volume_level: '{{ states.input_slider.volume_setpoint.state}}'
So for you it should like:
    platform: state
    entity_id: input_slider.sonos_volume
      data_template:
        volume_level: '{{ states.input_slider.sonos_volume.state }}'
This is untested and maybe don’t work. But it should be something in this direction.
input_slider.yaml
living_room:
  initial: 0.3
  min: 0
  max: 1
  step: 0.01
kitchen:
  initial: 0.3
  min: 0
  max: 1
  step: 0.01
Automation.yaml
- alias: living_room - Adjust Volume
    platform: state
    entity_id: input_slider.living_room
      data_template:
        entity_id: media_player.living_room_speakers
- alias: kitchen - Adjust Volume
    platform: state
    entity_id: input_slider.kitchen
      data_template:
        entity_id: media_player.kitchen_speakers
# second part of volume
- alias: kitchen - Volume
    platform: state
    - service: input_slider.select_value
      data_template:
        value: '{{ states.media_player.kitchen_speakers.attributes.volume_level }}'
- alias: living room - Volume
    platform: state
      data_template:
        value: '{{ states.media_player.living_room_speakers.attributes.volume_level }}'
this is working fine for me. Check the spaces though because I dont think im using the </> thing correctly.
@benjimatt - WORKING!!! WAHOOOO!!
I’ve been wanting to get this working for so long… THIS IS AMAZING!
It works perfect for Sonos… thank you so much…
Any ideas why the same script might not work with my sony bravia TV?
Interestingly I noticed even the volume control slider on the pop up dialog doesn’t work (only the clicking the volume icons will adjust the volume)
Hi… Looking good but seems not working in Version 47?
Output looks good but nothing happens.
Sven
  • alias: wohnzimmer - Adjust Volume
    platform: state
    entity_id: input_slider.sonos_lautstaerke_wohnzimmer
      data_template:
      entity_id: media_player.wohnzimmer
  • alias: wohnzimmer room - Volume
    platform: state
    • service: input_slider.select_value
      data_template:
      value: ‘{{ states.media_player.wohnzimmer.attributes.volume_level }}’
input_slider:
sonos_lautstaerke_wohnzimmer:
name: Vol. Wohnzimmer
initial: 0.2
min: 0
max: 1
step: 0.01
good evening,
i try this in the HA v. 0.57.2
my Code work with 3x Sonos:
Input_number.yaml
sonos_lautstaerke:
    initial: 6
    min: 1
    max: 20
    step: 1
automation.yaml
#### Sonos-Lautstärke
  - alias: Sonos Lautstärke
      platform: state
      entity_id: input_number.sonos_lautstaerke
        data_template:
          entity_id:
           - media_player.schlafzimmer
           - media_player.wohnzimmer
           - media_player.kueche
          volume_level: '{{ trigger.to_state.state | multiply(0.1) }}'
      platform: state
      entity_id: media_player.schlafzimmer
      - service: input_number.set_value
        data_template:
          value: '{{ states.media_player.schlafzimmer.attributes.volume_level }}'
And this work, the volume change if i switch the slider… but one Problem:
the log say:
WARNING (MainThread) [homeassistant.components.input_number] Invalid value: 0.09 (range 1.0 - 20.0)
someone has an idea?
What if you set the input_number min value to 0?
it’s change automatic to 0, when i change the volume…
With this works now perfect!
input_number.yaml
sonos_lautstaerke:
initial: 0.14
min: 0.01
max: 0.2
step: 0.01
automation.yaml
      platform: state
        data_template:
          entity_id:
          #volume_level: '{{ trigger.to_state.state | multiply(0.1) }}'
      platform: state
        data_template:
Thanks for these two automations. However, I guess they sometimes can end up in some kind of feedback loop, where one automation is triggered since the other changed the slider. Whenever I change the volume from outside of HASS, I will get this feedback loop. Is there any way to not have the set volume automation triggered if the input_number was updated by the second automation?
Just an FYI on Input_Number. When you look at the examples at the componants page you will see that the automations use "data_template: rather than “data:”. Hassio users like myself, will have to open your automations.conf file and manually edit the entry, changing “data:” to “data_template:” I beat my head against the wall for quite some time before I realized that.
