ygarti
(ygarti)
1
Hi All,
I have a TV that when she is off she doesn’t answer to ping (her NIC is off to)
now i have a standard switch that turn on or off the TV (using broadlink and IR)
what i want to achieve is to do a ping every 5 seconds and change the state of the switch
is this possible ? if so how do i do that (i am new and i have no idea how to achieve that
Thanks in advance
You can use this custom component, or use the ping binary sensor.
I prefer the first, because you could also control the volume and channels.
ygarti
(ygarti)
3
Thanks but i still don’t understand how can i combine them (i thing the ping binary is good enough)
this is my switch
switch:
- platform: broadlink
host: 10.0.0.1
mac: ‘00:00:00:00:00:00’
switches:
tv_lg:
command_on: ‘JgBQAAABJpMTDxQOETYREhEQFA4RERERGTQUMxERETcSNBQzETYRNxIPFA4RNhESEg8UDhE2ETYSNhE2Ew8UMxE2ETYTDxQOGQAFkQABJEkRAA0FAAAAAAAAAAA=’
command_off: ‘JgBQAAABJJISEhEQFDMREREREhATDxERETYRNhMPFDMRNhE2EzgTNBQzERERNxIPFA4RERE2EzQUDhE2ERISNBQzETYREhIPFAAFjwABJ0YRAA0FAAAAAAAAAAA=’
how do i use the ping binary sensor in that ?
You have to create a Template Switch.
For example:
switch:
switches:
tv_templated:
value_template: "{{ is_state('binary_sensor.ping_your_tv', 'on') }}"
turn_on:
service: switch.turn_on
entity_id: switch.tv_lg
turn_off:
service: switch.turn_off
