I am working on a flow for my Elk M1 security system. When I try to do things like set the keypad display text using the developer service tab, it works fine. But I am having trouble getting it to work in node-red. I watched the call_service events in the developer tab and here is what it looks like when I use the developer tab (which works correctly)
entity_id: alarm_control_panel.home
clear: 2
beep: 0
timeout: 10
line1: 'Clear'
line2: '51.1 deg F'
Event 0 fired 10:35 AM:
"event_type": "call_service",
"data": {
"domain": "elkm1",
"service": "alarm_display_message",
"service_data": {
"entity_id": "alarm_control_panel.home",
"clear": 2,
"beep": 0,
"timeout": 10,
"line1": "Clear",
"line2": "51.1 deg F"
"origin": "LOCAL",
"time_fired": "2020-12-25T15:35:05.082147+00:00",
"context": {
"id": "b5b6035697a6b1b5267e09e677d40e24",
"parent_id": null,
"user_id": "f9f3286363484ae6ab1a6f8fca3de911"
But when I run what I think should work in node-red, I get this:
Event 1 fired 10:36 AM:
"data": {
"domain": "elkm1",
"service_data": {}
"origin": "LOCAL",
"time_fired": "2020-12-25T15:36:55.805907+00:00",
"context": {
"id": "c9ab9b9ed6f3b623bc919636aef47f14",
"parent_id": null,
"user_id": "8acfd50682b247aa8cace63eda7841e9"
As you can see, the service_data is empty.
Here’s how I am currently trying (not working) to create the payload in a function node:
entity_id = "alarm_control_panel.home"
line1 = msg.payload.weather
line2 = Number.parseFloat(msg.payload.tempc * 9/5 + 32).toFixed(1) + " deg F"
clear = 2
beep = 0
timeout = 0
var newMsg = { "payload": {"entity_id": entity_id, "line1": line1, "line2": line2, "clear": clear, "beep": beep, "timeout": timeout }}
return newMsg;
This is creating a JSON message that looks like this:
"line1": "Mist",
"line2": "65.8 deg F",
"clear": 2,
"beep": 0,
"timeout": 0
and looks like this in the debug window:
entity_id: "alarm_control_panel.home"
line1: "Mist"
line2: "65.8 deg F"
clear: 2
beep: 0
timeout: 0
The elk integration folks have taken a look at this and are wondering if this is more of a node-red issue, most likely because I am not doing it right. I tend to agree with them.
Thoughts?
