Update: It does indeed have an effect, but in a different way than I had expected: if you set 0, for example, then 100% brightness is much lower than if you set 255, for example. I had assumed that the percentage value would change. I actually prefer it this way. Nice dimmer.
Hello everyone,
I hope you can help me. I have installed the following device:
Dimmer-Switch-ZB3.0 from HZC
It also works perfectly with the Sky Connect Stick, but I would like to set the parameter for the switch-on brightness for the evening. Unfortunately, this has no effect on the switch-on brightness. Do any of you know this hardware and can help me?
Best regards
