The first time I added my phone it only added it as an entity and the other steps were ignored.
After I toggled the advanced mode to off and on again the wizard started.
Careful with how much you crank that down. Devices do flap, and you want to be able to account for that.
It seems it used to be much more stable in older versions (I used to be able to do a 5 second timer), but now I’m using 120 seconds. That obviously introduces a bit of a delay, but IMO stability and accuracy is more important than immediacy - for the purposes that I use those sensors for.
