Hi Everyone, total HA noob here. Moving from Homeseer to HA. So far, most of the transition has been pretty easy, Just a few things I am having issues with. I installed the Ring integration and did the authentication. But when I look for anything ring I do not have any sensors or binary sensors.
I found a video from a while ago that showed setting it up in the configuration yaml file but it used username and passwords which I know no longer work because of the 2-factor. I cannot find a guide on how to use the integration with 2-factor and now sure what I did wrong in setting it up. Any advice or pointing in the right direction would be a big help.
Thank you
Mike
