I’d like to set up a very simple scene consisting of two smart plugs (an AVM DECT200 and an IKEA Tradfri plug). I can switch both separately on and off.
According to the docs it should be as simple as going to scene editor, create a new scene using the wanted devices, put them in the state I want them (ON in my case) and that’s it.
When I finally create a button card and try to switch my scene on I get an error saying something like “Error when calling the service scene/turn_off. Service not found”.
Can someone please help me and give me a hint on what I am doing wrong, where is my mistake?
Thank you in advance!
This is not a valid service call. First, it would be a ., not a /. Second, you are not able to “turn off” a scene. If you want to activate the scene, try scene.turn_on.
If you are still having trouble, can you post the YAML for your button card?
I am very sorry I discovered your answer just now - my notification settings were somehow turned off
I will try your suggestion as soon as possible and provide a feedback!
