I’m completely new to Home Assistant but I’m excited to get started! I want to make sure that I set things up correctly from the start, and I had a couple questions about choosing a thread border router. I have several Apple TVs around my house, but the only ones that use a wired ethernet connection are located in my AV rack in a basement closet. Does it matter if they are wired or wireless, and does the physical location of the device I use as my thread border router matter?
I live in a two-story home with a basement (so three levels). Should I choose one of the ethernet-connected Apple TVs in my basement closet or, or should I choose an Apple TV that’s located more centrally on the middle floor of my home, but that uses Wi-Fi for streaming and isn’t connected via ethernet?
I’ve ordered a Home Assistant Connect ZBT-2, but the only place I could find it available was wrong a store in England, so it might take a while to reach me in Los Angeles. Once I get it, will it be easy to switch my designated thread border router from an Apple TVs to the ZBT-2?
Welcome to HA — and good thinking to sort this out before you start adding devices, it’ll save you a lot of faff later.
Short answer: yes, location matters quite a bit, and wired vs wireless matters much less than you’d think.
The Thread radio in the border router is what actually talks to your devices, so it wants to be somewhere central with as little in the way as possible. A basement AV closet is pretty much the worst spot — low down, surrounded by other kit, and concrete floors don’t do the signal any favours. I’d go with the Apple TV on the middle floor even though it’s on Wi-Fi. The Wi-Fi connection only carries traffic back to Home Assistant, and that’s fine for the small amount of data Thread devices send. What matters is the radio being near the devices.
The other handy thing is you don’t have to pick just one — your Apple TVs can all act as border routers on the same Thread network, so the basement one can stay in the mix as a backup for anything down there.
And switching to the ZBT-2 later is straightforward. Once it’s set up in Home Assistant you can make it your preferred border router in the Thread integration settings, and because your devices stay on the same Thread network they should just carry on working — no re-pairing needed. Just give it a bit of time to settle after the switch.
Welcome to HA! Everything @JohnyMacclen says above rings true for me too. Especially the part about not picking just one Thread border router. Feel free to use them all. In fact, I think that happens automatically if you sign in with the same apple accounts. I have about 105 matter over thread devices in a three story house with an art studio about 30 feet away in the backyard. I have two wired Apple TVs and 4 HomePod Minis spread throughout. They all act as border routers. However, I have discovered that even turning them all off except for one in the house, the mesh still rebuilds quite well, even including the devices in the art studio. So location of the border router matters, but maybe just as important is the density of the thread devices. A single border router can reach the thread devices at the far reaches of your house or property as long as there are devices along the way that the connection can hop through. Have fun!
