Setting up backups and offloading the database hoses up Home Assistant?
I did a clean install of Hassbian, setup Samba, copied over my Yaml files, setup Spotify and TotaConnect. Everything was good. I didn’t have any errors other then some minor ones dealing with some sliders I need to fix. If I rebooted HASS, it also gave an error that it failed to run the restart service but it would still restart in a minute or less. It had always done that so no big deal. For the most part, everything was fine.
Then I tried to get fancy…
I used Tinkerer’s very well done guides located here as a guideline and did the following:
  1. Partitioned a USB drive into thirds. Used one partition to offload the database, the other for logs. This was to save on read/writes on the SD card.
  2. Setup rclone to upload an encrypted copy of my yaml files to Google Drive. Setup another remote of rclone to backup to the last partition on the USB. I tested and they worked. I then setup a cron job for each. The GDrive remote runs every hour and syncs any differences. The USB rclone job runs every hour and 10 minutes. Tested and all worked. I setup rclone to exclude the database, logs, etc when it syncs.
  3. Setup rpi-clone so I can manually clone my SD card to another that is plugged into the pi. This is not scheduled, I just run it manually.
After I performed all of that, I noticed I’m getting timer out of sync errors every 7-12 minutes. Also rebooting went from a minute or so to 20 minutes it seems. I looked at the CPU and memory usage but it doesn’t seem high really. Seems pretty normal. I removed the cron jobs and the same result. I’m beginning to think its an issue with moving the database, logs, etc to the USB? The USB is a verbatim 32GB split into roughly 10GB partitions.
Update: I’ve disabled logbook and history. Seeing what happens as far as errors.
Update 2: Looks like it is definitely dealing with the logs and such being on the USB. Not sure why it does that but I may just revert that part and not worry about offloading them.
