I’m setting up my Home Assistant to be reachable from outside my network, but need help doing it the ‘right’ way.
I have a pfSense router on which I’ve made some SSL certificates from Let’s Encrypt and use DuckDns as DDNS provider. Previously I’ve done the same directly on HA, but now I want more things to be accessible on the same address.
The SSL certificates from the router are connected to the domain I’ve made, right? So should I use the same certificates on my HomeAssistant installation? Can I generate another SSL certificate from Let’s Encrypt based on the same domain, and should I?
A certificate is linked to a domain, e.g. “mydomain.duckdns.org”.
As long as the service being called, whether HA or on your router, is called via a “https://mydomain.duckdns.org…” url, the same certificates can be reused.
