Setting up Fan Control Entity Row for Tuya Fan
Hello all,
I’m trying to get me Tuya fans to work with the Fan Control Entity Row Card and I’ve been searching all over the boards with no luck on how the code editor should read. I attached pics of my setup. Any help is appreciated!
I don’t think I ever set that plugin to work with the UI editor.
You will have to create it in yaml.
But the yaml you have there should get you started.
Is that not working?
Oh and btw, that plugin won’t work with the new fan control modes that HA has switched to.
Unless you are on an older version of HA you now have to use either fan-percent-button-row or fan-mode-button-row.
Ok, no its not working.
I was unaware about the fan percent button row or fan mode button row.
Found the cards in HACS.
Seems to be working in my livingroom fan. I’ll check the status of the bedroom fan tomorrow (wife’s asleep).
Thanks for the help!
