Do you think it would be possible to assign a room in the customize declaration?
Looks like project.json is a directory in your CMD window, it should be a file.
Create a file called project.json and put the code from step 2 under āSetupā
Iām trying to use emulated hue on Google Home but I am not sure where to discover devices exposed by emulated hue. In Alexa, I just click on the Discover button in the Alexa app. Where do I click in the GH app?
This thread is about the new Google Assistant component, not Hue. If youāre looking for help on Emulated Hue Iād ask in another thread to avoid confusion.
link philips hue. If there unlink and relink
I did a file project.json equal to tutorial and placed in a paste called project.json, now I renamed the paste but still canĀ“t receive the URL, I didnĀ“t installed duck dns and letĀ“s encrypt, maybe itĀ“s this?
If you donāt use letās encrypt and duck dns (or any other dns and https certificate) it wonāt work.
Itās a requirement from Google that youāre home-assistant is accessed through https and not http.
tkss very much IĀ“ll installed and try again, itĀ“s obligated to have both or can I have only letĀ“s encrypt?
You can, but you need a fixed address for your home-assistant instance (accessible from Internet).
DuckDNS allow you to have a fix public address for your home-assistant instance.
ok ks again IĀ“ll try through duck dns
not sure if this is a good idea as there are loads issues with people trying to connect the GH to emulated hue as you have to link GH to philips site and google & philips has made that more or less ā¦ that is why everybody was waiting for this functionality
Yep, I never got it working with the emulated hueā¦ philips would not let me link the emulated hue to google.
So i have this working fine but after a couple of hours, when asking assistant on my phone to do anything it returns āIām sorry, there was an error and i am unable to control your home deviceā.
I then unlink the account, relink it, assign rooms and it works again. Until it breaks again.
Seems like some sort of timeout on something (auth token?) but I donāt see any timers. Any ideas?
some conflicting names?
How would I know if thatās an issue? All names in home assistant are unique at least. I do have IFTTT as well but rhe overlapping recipes there are disabled
similar names and rooms
Guest Room
Guest Room Light
Room Light
Guest Light
havenāt tested well, but once I have similar names, I do get problems
I just have office, kitchen and living room which have just office lights, coffee machine and tv lights. I donāt expose anything else by default. So seems unlikely that itās a naming problem.
yes you are right: take into consideration also group name in hass, and room name in gh app
I noticed I got this error after trying to use the simulator to test things. It would work once in the simulator, then stop working across all devices and the simulator. After re-linking and leaving the simulator alone itās been solid for a few days now (fingers crossed).
I have the same issue, after a while it breaks, timeout issue ?
Iām using my domain with nginx proxy, letās encrypt.
