Couldn’t update the setting. Check your connection
Same here. I’ve repeated the process twice to no avail. Any ideas on what’s needed to get past the “Couldn’t update the setting” hurdle?
I used my phone’s internet data
Clever. I have everything setup to allow access to the server to the same domain name (https) from inside and outside my network. I tried to swap my phone off network anyway, same error.
Are you guys using both the GA add-on and the component at the same time on your HA?
tks very much! I working on windows but my hassio is on my raspberry so I supposed i can use this site, when the instructions says an URL do I need to make on my on example Http://example.mycode.?
I can only get this to work with lights. If I try to enable switches, it wont update the list and if I try to re-link the app, I get that damn error…
It has to be an issue with the amount of devices I have set up… I have 6 lights and those all work fine. I have about 10 switches though, which may be causing the link issues
I’m using Hass.IO but I’m not using the addon, I downloaded the gactions
executable to my /config dir and ran it successfully from there.
For hass.io is it advisable to run the addon instead?
Thanks.
I have 98 devices, probably 40 lights and 20 switches … and its working fine
just faceroll over the keyboard, delete all symbols and its ready to go
@clintos that’s how I got mine paired, I did a small testing and it seemed to be working but because I still have emulated_hue installed everything was considered a clone and only worked if I gave it an alias within the app.
On hass.io I only copied the default configuration, adjusted the project_id, client_id and accesss_token and let exposed_domains switch, light, group as it was
gacions I downloaded on my laptop since I only use it to upload the json file
@plonka2000 I use Hass.io and don’t use the Google Assistant addon, I own a real Google Assistant.
Also, I don’t want to run any local voice services, just via a Google Home or Android device separately.
Is the add-on installation suitable for this?
I had a look at the docs and it seems like its for much more, needing sound devices configured…
Can you advise if there is a path to using this for only external devices?
Thanks.
@Sthope thanks for responding.
Do you have any specifics about how you got yours running in hass.io?
executable into a folder in my /config
and ran it from there. It seems to work, doesnt complain.
I set up the URL in a project.json
file (The URL in the project.json
needs /auth
at the end also?) per the docs.
Am I missing something?
I don’t get it then… Here is my config:
google_assistant:
project_id: *my project id from dev console*
client_id: *20 char alphanumeric string*
access_token: *80 char alphanumeric string*
exposed_domains:
- light
- switch
Since my app is now linked, why wont it update either?
No the URL in project.json it is like “https://plonka2000.duckdns.org:8123/api/google_assistant”
@timmo001 I think said few posts above that it doesn’t update automatically you have to remove and add it again on Google Home app
So, I’ve noticed youre using DuckDNS as an example, direct to HA using a keychain file directly in your configuration.yaml
I’m using nginx+letsencrypt locally to front Home Assistant, which works very well, but that means that the HA instance is running HTTP behind the HTTPS nginx+letsencrypt.
So the URL I use is something like “https://home.myowndomain.com/api/google_assistant”
Works great for everything I’ve used it for, so I’m not sure nginx is the problem, but its possible.
I’m rebuilding the app project from scratch again and rebuilding to see what may change.
OK, that’s fair enough.
I think I’ve fixed it. So, I did the usual debug process of commenting all non-essential components and found that I had an unnamed switch listed on the frontend. So I removed some of the yaml files for switches and that seemed to have fixed it. I now have lights and switches working through google assistant.
Odd that was the cause of my pain a switch with no name, not causing any errors… I can now add more domains without issue. I just need to re-link every time I add a device which isn’t the greatest of issues but hopefully will be fixed in a later version. Great work on this component, it seems to be somewhat faster and a lot better than seeing all my switches act as lights
Using the addon and dialogflow you can do many other things the component can’t still do, for example you can ask the temperature at home if you have a temperature sensor. And if you say “Ok google” to your phone and to the HASSIO device, only one of them will answer to you, because the other one knows the first one is answering.
try unlik and link again
you can do this now??
Hey thanks everyone!
I got it working on Android for now!
I think as @timmo001 said, I also probably have some devices not listing correctly now.
I can see in now in my HA Log many of these entries when pulling in my device lists:
WARNING (MainThread) [homeassistant.components.google_assistant.smart_home] aliases must be a list
WARNING (MainThread) [homeassistant.components.google_assistant.http] No mapping for script domain
I guess I’ll need to go through my customize
and add aliases for everything.
Currently I have 78 devices listed.
yes, I can do that, but not both at the same time. I’m having some problems with authorizations, credentials and stuff… only one of the two works. I’m not sure it’s possible
