Setting Up HassIO with DuckDNS
Hi there,
a few days ago i just switched from Openhab2 to HassIO (HomeAssistant) because i like the WebUI in HA.
After i included all my devices into HA (stuff like Hue, Max!, Yeelight, Sonoff, etc.) im now trying to get external access to HA. There im still struggling. I installed DuckDNS, set it up at duckdns.org and afterwards i activated port forwarding in my router from 443>8123 and also 8123>8123. When i try to reach HA via https:// xxx . duckdns . org i cant reach it. Only by using http:// xxx . duckdns . org: 8123 it is working fine. But as i understand that there is no encryption when using http://…
I just want to encrypt the connection. So i try to deactivate the http: access and activate the https: access.
Can someone help me out with this?
Thank you a lot.
Kind regards,
Weberan
configuration.yaml:
http:
  base_url: https://xxx.duckdns.org
DuckDNS Setup:
  "lets_encrypt": {
    "accept_terms": true,
    "certfile": "fullchain.pem",
    "keyfile": "privkey.pem"
  "token": "my token",
  "domains": [
    "xxx . duckdns . org"
  "seconds": 300
Theres a component in Hass that will effectively do all of this for you.
Also, use triple backticks(`) to maintain the formatting of you code. One extra whitespace can be the difference between working, and not working
also, in the article you linked, the base URL has to have a https://.... but your base URL doesn’t have that above.
Argh, thanks. Just found out that i had a second instance of “http:” at the bottom of configuration.yaml. There it was already https:…
Also i used the DuckDNS package which you linked in your earlier comment.
What do you mean with ‘’'? Should i add this to my yaml-File or here when posting some yaml snippets? Srr i dont get it yet.
After playing around and deleting the port forwarding except 8123>8123 (because it is told that you dont need port forwarding in the link above). After a restart i think i dont get any encryption files. The DuckDNS log tells me that:
starting version 3.2.2
INFO: Using main config file /data/workdir/config
  • Generating account key…
  • Registering account key with ACME server…
  • Done!
    Sat Dec 16 14:20:51 CET 2017: KO
Processing xxx.duckdns.org
  • Signing domains…
  • Creating new directory /data/letsencrypt/xxx.duckdns.org …
  • Generating private key…
  • Generating signing request…
  • Requesting challenge for xxx.duckdns.org
    KO + Responding to challenge for xxx.duckdns.org
    KOUnknown hook invalid_challenge
    ERROR: Challenge is invalid! (returned: invalid) (result: {
    “type”: “dns-01”,
    “status”: “invalid”,
    “error”: {
    “type”: “urn:acme:error:unauthorized”,
    “detail”: “Correct value not found for DNS challenge”,
    “status”: 403
    “uri”: “https://acme-v01.api.letsencrypt.org/acme/challenge/xxx”,
    “token”: “xxx”,
    “keyAuthorization”: “xxx”
    Sat Dec 16 14:26:23 CET 2017: KO
    Sat Dec 16 14:31:24 CET 2017: KO
Do you know what the problem can be? Thanks a lot for your help.
When posting code in the forums, use `` ` (no space!) at the start and end of the code.
Like this  ...
Alright. Just edited the first entry.
403 meants forbidden.
Can you now access your HA internally by going to https://the-IP-internal-address:8123?
Unfortunately not. The error code which is desplayed within mozilla is:
Fehlercode: SSL_ERROR_RX_RECORD_TOO_LONG
Edit:
Never mind. I got some help from a friend. He just found out that my base_url within the configuration.yaml is not within quotes “”. So now my setting is:
configuration.yaml
http:
  # Secrets are defined in the file secrets.yaml
  api_password: !secret http_password
  # Uncomment this if you are using SSL/TLS, running in Docker container, etc.
  base_url: "xxx.duckdns.org:8123" # without https: but within quotes!
  ssl_certificate: "/ssl/fullchain.pem"
  ssl_key: "/ssl/privkey.pem"
  ip_ban_enabled: True
  login_attempts_threshold: 20
DuckDNS:
  "lets_encrypt": {
  "token": "xxx",
  "domains": [
    "xxx.duckdns.org"
  "seconds": 300
And within the router i made the port forwarding from 443 > 8123.
So now i can reach my HassIO over : https://xxx.duckdns.org
