I am trying to follow the instructions for setting up a development environment (on Linux, Ubuntu 22.04), and I am encountering multiple issues:
- When setting up the core dependencies, the package
libavresample-dev
does not exist. Based on comments in other threads, I replaced it withlibswresample-dev
- but I was unable to confirm that this is the correct solution. - When running
script/setup
, the script exits with an error:
Requirement already satisfied: h11<0.15,>=0.13 in ./venv/lib/python3.10/site-packages (from httpcore<0.19.0,>=0.18.0->httpx>=0.21.0->respx==0.20.2->-r requirements_test.txt (line 33)) (0.14.0)
pre-commit installed at .git/hooks/pre-commit
Usage:
/home/bogd/hass-core/venv/bin/python3 -m pip install [options] <requirement specifier> [package-index-options] ...
/home/bogd/hass-core/venv/bin/python3 -m pip install [options] -r <requirements file> [package-index-options] ...
/home/bogd/hass-core/venv/bin/python3 -m pip install [options] [-e] <vcs project url> ...
/home/bogd/hass-core/venv/bin/python3 -m pip install [options] [-e] <local project path> ...
/home/bogd/hass-core/venv/bin/python3 -m pip install [options] <archive url/path> ...
no such option: --config-settings
As far as I can tell, this is caused by line 27 of the script:
python3 -m pip install -e . --config-settings editable_mode=compat --constraint homeassistant/package_constraints.txt
- When trying to set up the integration scaffold, the
script.scaffold
module exits with:
(venv) bogd@dev-hass:~/hass-core$ python3 -m script.scaffold integration
File "/usr/lib/python3.10/runpy.py", line 196, in _run_module_as_main
return _run_code(code, main_globals, None,
File "/usr/lib/python3.10/runpy.py", line 86, in _run_code
exec(code, run_globals)
File "/home/bogd/hass-core/script/scaffold/__main__.py", line 7, in <module>
from . import docs, error, gather_info, generate
File "/home/bogd/hass-core/script/scaffold/gather_info.py", line 4, in <module>
from homeassistant.util import slugify
File "/home/bogd/hass-core/homeassistant/util/__init__.py", line 16, in <module>
from .dt import as_local, utcnow
File "/home/bogd/hass-core/homeassistant/util/dt.py", line 17, in <module>
UTC = dt.UTC
AttributeError: module 'datetime' has no attribute 'UTC'
- (possibly as a result of 2?) - there is no
hass
command in my venv:
(venv) bogd@dev-hass:~/hass-core$ hass
Command 'hass' not found, did you mean:
command 'cass' from snap cass (0.17.2)
command 'sass' from deb ruby-sass (3.7.4-5)
command 'pass' from deb pass (1.7.4-5)
command 'ass' from deb irpas (0.10-9)
See 'snap info <snapname>' for additional versions.
This is on a fresh install of Ubuntu 22.04, with Python 3.10.12
Can anyone point me in the right direction?
Thank you!
