Hi there
I’m planning on learning how to write a super simple integration to dip my toes in to the world of developing for HA. Unfortunately falling at the first hurdle though. Following the documentation here - https://developers.home-assistant.io/docs/development_environment, I am attempting to spin up a devcontainer environment in vscode on my machine (Linux Mint 19.3) but getting the following error mid way through the build. Have tried a few times and always fails at the same point:
[2021-06-07T21:23:11.594Z] [PID 16654] [263315 ms]
[2021-06-07T21:23:11.594Z] [PID 16654] [263315 ms] Start: Run in container: # Copy /home/paul/.gnupg/trustdb.gpg to /root/.gnupg/trustdb.gpg
[2021-06-07T21:23:11.601Z] [PID 16654] [263322 ms]
[2021-06-07T21:23:11.602Z] [PID 16654] [263323 ms]
[2021-06-07T21:23:11.602Z] [PID 16654] [263323 ms] Start: Run in container: set -o noclobber ; mkdir -p '/root/.vscode-server/data/Machine' && { > '/root/.vscode-server/data/Machine/.postCreateCommandMarker' ; } 2> /dev/null
[2021-06-07T21:23:11.602Z] [PID 16654] [263323 ms] Start: Run: gpg-connect-agent updatestartuptty /bye
[2021-06-07T21:23:11.614Z] [PID 16654] [263335 ms]
[2021-06-07T21:23:11.614Z] [PID 16654] [263335 ms] Start: Run in container: test -f /root/.vscode-server/.postCreateCommandMarker
[2021-06-07T21:23:11.621Z] [PID 16654] [263342 ms]
[2021-06-07T21:23:11.621Z] [PID 16654] [263342 ms] Exit code 1
[2021-06-07T21:23:11.804Z] [PID 16654] [263525 ms] Start: Run: docker exec -i -u root -e SSH_AUTH_SOCK=/tmp/vscode-ssh-auth-0b86a1b0b0d07bf20ddcef6eb12d3bc67f2ca626.sock -e REMOTE_CONTAINERS_IPC=/tmp/vscode-remote-containers-ipc-0b86a1b0b0d07bf20ddcef6eb12d3bc67f2ca626.sock -e REMOTE_CONTAINERS=true -w /workspaces/core 258f44ea65169fee1e65905db29e8a9306f8d36597fef7814a49bccba4008e6f /bin/sh -c script/setup
[2021-06-07T21:23:11.918Z] [PID 16654] [263639 ms] Installing development dependencies...
[2021-06-07T21:23:12.176Z] [PID 16654] [263897 ms] Command failed: /bin/sh -c script/setup
Any ideas?
