Setting up local USB printer with CUPS via Portainer
Logs are only for “Business User” :confused:
What do you mean with “Host Port”?
I leave the Portainer Port but i change the Port from which device?
Sorry Iam new to this :slight_smile: But thanks for heloing me out here!
You should be able to see the logs by clicking on the Logs under Quick Actions like in the image below:
What I meant by Host Port is the previous instructions that I sent.
Instead of using 631 to Host, change to 6631:
Ah okay.
The log repeats the same every second:
2024-10-31T22:44:07.278513000Z New password: Retype new password: passwd: password updated successfully
Tried the different host port but it looks like it’s changed nothing. The log isn’t different after the change.
Hi @Squall40
I’m not very familiar with the cups container used in HA.
I ended up setting up a different cups in a separate docker server in order to auto turn on/off the printer.
Take a look at this thread. They mentioned cups addon.
Okay no Problem, thanks for the help anyways =)
I’ll look at your link, i hope this will fix my issue!
Have a great Sunday
I recently installed Hass and want to add an USB printer to my network (samsung m2675F). I already dowloaded the CUPS integrations and added my printer to it with the integrated driver for it (Samsung M267x 287x Series PXL).
I can see the printer from any device connected to my network. It also detected on the hass installation (rapsi 5) as an IPP printer.
However when I try to print the test page from CUPS the message “If you can read this you are using the wrong driver for your printer”. When I try to print from a device nothing happend.
If anyone has already had this issue…
Please excuse my english I’m not native.
