I have problem setting up the Mosquitto broker add-on in Hassio.
I receive following error in the logger:
[20:32:54] INFO: Setup mosquitto configuration
[20:32:55] INFO: No local user available
[20:32:55] INFO: Initialize Hass.io Add-on services
[20:32:55] INFO: Initialize Home Assistant discovery
[20:32:55] INFO: Start Mosquitto daemon
1578598375: Loading config file /share/mosquitto/acesscontrollist.conf
1578598375: Error: Duplicate user value in configuration.
1578598375: Error found at /share/mosquitto/acesscontrollist.conf:1.
1578598375: Error found at /etc/mosquitto.conf:29.
Yes, I have created a new user in Hassio, Configuration > Users (manage users).
User āmqtt_freddaā.
Now I even tried to delete and creat the user again.
But it still gives me the same error.
Iām also having an issue getting Mosquitto going. I have a raspberry pi3 and Iām trying to run it on my GoControl zigbee dongle. This is the error Iām getting (please help):
code ELIFECYCLE
npm
ERR! errno 1
npm
ERR! [email protected] start: node index.js
npm ERR! Exit status 1
npm
ERR!
npm ERR! Failed at the [email protected] start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm
ERR! /root/.npm/_logs/2020-03-11T06_23_43_346Z-debug.log
2020-03-11T01:23:44: PM2 log: App [npm:0] exited with code [1] via signal [SIGINT]
2020-03-11T01:23:44: PM2 log: App [npm:0] starting in -fork mode-
2020-03-11T01:23:44: PM2 log: App [npm:0] online
