Setting up razberry on a raspberry pi 2 running Hass.io
I have tried everything I have found in the documentation but nothing seems to work.
I did all the steps in this:
Looking at https://home-assistant.io/docs/z-wave/ I can’t get past the first command since there is not apt-get.
Some forum posts suggests editing the /boot/config.txt and enabling uart but I have no /boot dir!
Running ls /dev/tty* results in /dev/tty, ie I have no ttyAMA0.
Im a bit frustrated since switching from openHAB thinking hass would be so much easier. It has not lived up to its reputation yet. Though the installation up till now is really smooth I have to say. But without z-wave…
Can anyone help me please?
This is really strange. I installed a fresh Hass.io image on my pi last night and tried to configure z-wave before I went to bed. Today after fiddling a bit not changing any configuration I saw that I had z-wave devices reporting stuff on the States screen and now I have Z-wave under configuration. I am sure I didnt do anything to make it happen and I did not reboot.
I did try to install Z-way but without success. Maybe that script did something to enable the UART!?
core-ssh:/home/zway# wget -q -O - razberry.z-wave.me/install | bash
Do you accept Z-Wave.Me licence agreement?
Please read it on Z-Wave.Me web site: http://razberry.z-wave.me/docs/ZWAYEULA.pdf
yes/no: yes
z-way-server new installation
Installing additional libraries
bash: line 65: apt-get: command not found
bash: line 66: apt-get: command not found
Installing additional libraries for HomeKit
bash: line 73: apt-get: command not found
Making symlinks to libssl.so
bash: line 79: cd: /usr/lib/arm-linux-gnueabihf/: No such file or directory
Making symlinks to libcrypto.so
bash: line 86: cd: /usr/lib/arm-linux-gnueabihf/: No such file or directory
Installing libarchive-dev
bash: line 94: apt-get: command not found
Making link to libarchive.so.12
ln: /usr/lib/arm-linux-gnueabihf/libarchive.so.12: No such file or directory
Getting Z-Way for Raspberry Pi and installing
wget: unrecognized option: 4
BusyBox v1.26.2 (2017-05-23 16:46:32 GMT) multi-call binary.
Usage: wget [-c|--continue] [--spider] [-q|--quiet] [-O|--output-document FILE]
	[--header 'header: value'] [-Y|--proxy on/off] [-P DIR]
	[-U|--user-agent AGENT] [-T SEC] URL...
Retrieve files via HTTP or FTP
	--spider	Spider mode - only check file existence
	-c		Continue retrieval of aborted transfer
	-q		Quiet
	-P DIR		Save to DIR (default .)
	-T SEC		Network read timeout is SEC seconds
	-O FILE		Save to FILE ('-' for stdout)
	-U STR		Use STR for User-Agent header
	-Y on/off	Use proxy
Extracting new z-way-server
tar: can't open '/tmp/z-way-server-RaspberryPiXTools-v2.3.5.tgz': No such file or directory
mv: can't rename '/tmp/z-way-server': No such file or directory
New version z-way-server installed
Creating Z-Way startup script
Adding z-way-server to autostart
bash: line 280: update-rc.d: command not found
Getting Webif for Raspberry Pi and installing
	-q		Quiet
	-Y on/off	Use proxy
tar: invalid magic
tar: short read
First install, getting Remote ID
	-q		Quiet
	-Y on/off	Use proxy
Getting webserver mongoose for Webif
	-q		Quiet
	-Y on/off	Use proxy
tar: can't open '/tmp/mongoose.pkg.rPi.tgz': No such file or directory
Adding mongoose to autostart
bash: line 474: update-rc.d: command not found
Start mongoose http server
bash: line 478: /etc/init.d/mongoose: No such file or directory
sed: /boot/cmdline.txt: No such file or directory
bash: line 507: cd: /opt/z-way-server: No such file or directory
diff: can't stat '/boot/cmdline.txt': No such file or directory
Starting z-way-server
Starting z-way-server: done.
Do you want to receive emails with news about RaZberry project?
! Please subscribe again if you did it before 30.03.2013
yes/no: no
Thank you for using RaZberry!
