Had a bunch of issues with base-url and other stuff that I seem to have sorted out. Now when I go through the SmartThings Integration, I get “Unknown error occurred” after submitting my personal Token. Checking into the logs, I see I’m getting a 403 Forbidden from SmartThings…any ideas? Did something change, or is there something else I’m missing?
Logger: aiohttp.server
Source: components/smartthings/config_flow.py:175
First occurred: 12:43:22 AM (1 occurrences)
Last logged: 12:43:22 AM
Error handling request
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 418, in start
resp = await task
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_app.py", line 458, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 18, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 72, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 127, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 129, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 169, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 60, in wrapper
result = await method(view, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 106, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 153, in async_configure
result = await self._async_handle_step(flow, cur_step["step_id"], user_input)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 201, in _async_handle_step
result: Dict = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/smartthings/config_flow.py", line 166, in async_step_pat
return await self.async_step_select_location()
File "/usr/src/homeassistant/homeassistant/components/smartthings/config_flow.py", line 175, in async_step_select_location
locations = await self.api.locations()
File "/usr/local/lib/python3.8/site-packages/pysmartthings/smartthings.py", line 38, in locations
resp = await self._service.get_locations()
File "/usr/local/lib/python3.8/site-packages/pysmartthings/api.py", line 53, in get_locations
return await self.get_items(API_LOCATIONS)
File "/usr/local/lib/python3.8/site-packages/pysmartthings/api.py", line 384, in get_items
resp = await self.request("get", self._api_base + resource, params, None)
File "/usr/local/lib/python3.8/site-packages/pysmartthings/api.py", line 376, in request
resp.raise_for_status()
File "/usr/local/lib/python3.8/site-packages/aiohttp/client_reqrep.py", line 941, in raise_for_status
raise ClientResponseError(
aiohttp.client_exceptions.ClientResponseError: 403, message='Forbidden', url=URL('https://api.smartthings.com/v1/locations')
