Setting up special mode for a room and using wallpanel for it
When we have sleepover guests, they sleep in our livingroom.
In the livingroom we hhave some automated lights, and a motionsensor, so that is not ideal when you are sleeping.
We also have a tablet running wallpanel, that gives out quite a lot of light, so I need to set the room to ‘sleepover guests’.
First of I have defined an input_boolan for the status:
  sleepover_guests:
    name: Marks if there are sleepover guests
    icon: mdi:sleep
All the automations for that room, then checks if it is set to off, here is an example for our ‘nightlight’ automation, we have others of course, but the idea is the same for them all.:
- id: '1558893031102'
  alias: Livingroom - Nightlight
  - entity_id: binary_sensor.livingroom_movement
    platform: state
    to: 'on'
  condition:
  - condition: state
    entity_id: input_boolean.sleepover_guests
    state: 'off'
  - below: '1'
    condition: numeric_state
    entity_id: sensor.livingroom_lux
  - condition: state
    entity_id: light.tapetlampe
    state: 'off'
  - data:
      brightness_pct: 10
    service: light.turn_on
  - data:
      entity_id: input_boolean.nightlight_livingroom
    service: homeassistant.turn_on
Then at noon, the sleepover_guests is reset:
- id: '1565774404861'
  alias: Tablet - sleepover mode - timed reset
  - at: '12:00'
    platform: time
  condition:
  - condition: state
    state: 'on'
  - data:
    service: homeassistant.turn_off
The real magic is with the wallpanel app by thanksmister. It can be controlled with mqtt (the tablet has the topic wallpanel/livingroom), so it’s a breaze.
I’ve created two dashboards for this, the normal one, and the sleepoverguests one.
The normal one (fribert.dash), I have a lot more definitions of course, for all the other tiles, but I’ll just show the important lines:
## Main arguments, all optional
## Acer Iconia 1280x800
title: Hovedside
widget_dimensions: [123,128]
widget_size: [1, 1]
widget_margins: [5, 5]
columns: 10
global_parameters:
    use_comma: 0
    precision: 1
    use_hass_icon: 1
    namespace: default
overnightguests:
    widget_type: input_boolean
    title: Gæster i stuen
    entity:  input_boolean.sleepover_guests
layout:
    - clock (2x1), lian, kenneth, nathalie, adrian, frontdoor (4x3)
    - glasmontre, dvd_reoler, tapetlampe, barskab, treklover  , nathalieloft
    - spisebord, kokkenbord, vitrine, spejl, kontor, sovevaerelselys
    - kaffemaskine, fluefanger, trappe, gang, adrianloft, spacer, have, pool, vandsten,yrpicture
    - stueetage, 1stesal, spacer, spacer
    - kokkenthermostat, stuethermostat, livingroomtemp, adrianthermostat, nathaliethermostat ,entretemp ,bathtemp ,havetemp, frontdoorlock, overnightguests
Then I have the ‘sleepover guests’ panel (blank.dash):
title: Hovedside
widget_size: [1, 1]
columns: 10
global_parameters:
    use_comma: 0
    precision: 1
    use_hass_icon: 1
    namespace: default
overnightguests:
layout:
    - spacer, spacer, spacer, spacer, spacer, spacer, spacer, spacer, spacer, overnightguests
To support these two panels, I have to home assistant automations.
The first one sets the room to sleepover mode, it changes the brightness in the tablet, turns off the nightlight in the room (if it is activated, by resetting the boolean that marks that), then turns off all christmas lights in the livingroom, and changes the dashboard:
- id: '1560365252406'
  - entity_id: input_boolean.sleepover_guests
    platform: state
    to: 'on'
  condition: []
  - data:
      payload: '{''brightness'': 1}'
      qos: 1
      topic: wallpanel/livingroompanel/command
    service: mqtt.publish
  - data:
      payload: '{''url'': ''http://homeassistant.fribert.dk:5050/blank'' }'
      qos: 1
  - data:
    service: light.turn_off
  - data:
    service: input_boolean.turn_off
  - data:
      entity_id: group.all_stue_julelys
Then there is the ‘opposite’, to make the room go ‘normal’ again:
- id: '1560366115523'
  alias: Tablet - normal mode
    platform: state
    to: 'off'
  condition: []
  - data:
      payload: '{''brightness'': 100}'
      qos: 1
  - data:
      payload: '{''url'': ''http://homeassistant.fribert.dk:5050/fribert'' }'
      qos: 1
The panels looks like this, sorry for the bad quality pictures:
The normal panel (the sleepover guests button is at the bottom right)
Then the sleepover mode, button is in the same position.
I hope this is understandable, and helps somebody that has the same needs.
