Setting up switchbot curtain 3 via switchbot hub mini
Got a pair of switchbot curtain 3. I just bought a hub mini so I could control them from home assistant.
I see that curtain 3 is mentioned on the bluetooth home assistant integration, but not the cloud one. I wanted to use the cloud because my HA is too far away from the curtains for reliable bluetooth connection, so i thought I’d bypass that with the hub. Can I use the curtains via the hub in HA?
I have a matter dongle, but when I scan the QR code sticker on the hub or the curtain controller, it just gives an error. I’m not sure if I can set it up this way.
Having looked at this given the lack of support I’m going to get a couple of m5stack atom lites, which provides Bluetooth and solves the range issue.
