Ted_Gore
(Ted Gore)
December 26, 2017, 5:38pm
1
I have two light switches in a room that control two separate lights. I want to setup an automation that will turn on the other light to the same brightness level as the light that is turned on. So, if either of the switches are turned on to a specific brightness level, the other light switch will turn on and match it, and visa versa.
Additionally have it setup so that the brightness between the two switches is always synced regardless of which switch the brightness is changed on.
I’m a newb, and I don’t even really know where to start. Any help with the syntax on this?
Thanks!
edif30
December 30, 2017, 9:21pm
2
Here you go…
sensors:
brightness_test:
friendly_name: "Brightness Test"
value_template: '{{ states.light.test_lamp_1.attributes.brightness }}'
automation:
- id: 'brightness test'
alias: brightness test
- platform: state
entity_id: sensor.brightness_test
- service: light.turn_on
entity_id: light.test_lamp_2
- delay: '00:00:03'
data_template:
brightness: '{{ states.sensor.brightness_test.state }}
kylerw
(Kylerw)
December 30, 2017, 11:33pm
3
THese two automations should do it without the extra sensor. It has a trigger that watches for a state change and if the change is different than the current brightness of the other light, it will update the other light.
I haven’t checked the syntax so there may be errors but this should give you some guidance.
alias: "light1 > light2"
platform: state
entity_id: light.light1
condition:
condition: template
value_template: "{{ not is_state_attr('light.light1_level', 'brightness', states.light.light2_level.attributes.brightness ) }}"
data_template:
entity_id: input_slider.playbar_volume
value: "{{ trigger.to_state.attributes.brightness }}"
alias: "light2 > light1"
platform: state
entity_id: light.light2
condition:
condition: template
value_template: "{{ not is_state_attr('light.light2_level', 'brightness', states.light.light1_level.attributes.brightness ) }}"
data_template:
I’m looking for this but with color included.
Is adding a color option just as easy?
Ted_Gore
(Ted Gore)
May 24, 2020, 3:45pm
5
Hey, this is what I ended up setting up that is currently working for brightness:
- id: '1589816799447'
alias: Cabinet Brightness 1 to 2
description: ''
- entity_id: light.kitchen_under_cabinet_1
platform: state
condition: []
- delay: 00:00:01
- data_template:
brightness: '{{ states.sensor.brightness_cabinet1.state }}'
entity_id: light.kitchen_under_cabinet_2
And then another one going the other direction. The automation is using two sensors I created in the config for the brightness values, like this…
sensors:
brightness_cabinet1:
friendly_name: "Brightness Cabinet 1"
value_template: '{{ states.light.kitchen_under_cabinet_1.attributes.brightness }}'
sensors:
brightness_cabinet2:
friendly_name: "Brightness Cabinet 2"
value_template: '{{ states.light.kitchen_under_cabinet_2.attributes.brightness }}'
I’m no expert, but I imagine you could just create two more sensors for the rgb value of each of the lights, like this…
sensors:
rgb_cabinet1:
friendly_name: "RGB Cabinet 1"
value_template: '{{ states.light.kitchen_under_cabinet_1.attributes.rgb_color }}'
sensors:
rgb_cabinet2:
friendly_name: "RGB Cabinet 2"
value_template: '{{ states.light.kitchen_under_cabinet_2.attributes.rgb_color }}'
And add in another line under the data_template for the RGB value in the automation, like this…
- data_template:
rgb_color: '{{ states.sensor.rgb_cabinet1.state }}'
Like, I said, I’m no expert with this, and I have no way to test this because I don’t have any lights that can change color, but give it a try!
jeffre
(jeffre)
August 11, 2020, 1:00am
7
I came across this post doing a google search. The example by @Ted_Gore does not work because rgb_color expects a list and his code will return a string. Thankfully, we can overcome this limitation by breaking each color out like this:
data_template:
brightness: '{{ states.light.hallway_light_1.attributes.brightness }}'
rgb_color:
- '{{ states.light.hallway_light_1.attributes.rgb_color[0] }}'
- '{{ states.light.hallway_light_1.attributes.rgb_color[1] }}'
- '{{ states.light.hallway_light_1.attributes.rgb_color[2] }}'
jedixi
(Jed Levin)
March 7, 2021, 6:59pm
8
For anyone fighting this like I was, I’m using a sensor that outputs in percentage. The lights I’m using take brightness on a scale of 0-255. Here’s what I used that worked (please note the conversion to float, then multiply by 2.55):
alias: Kitchen Cabinets Brightness
description: ''
- platform: state
entity_id: sensor.kitchen_periodic_lights
entity_id: light.kitchen_cabinets_right
data_template:
brightness: '{{ states.sensor.kitchen_periodic_lights.state|float * 2.55 }}'
entity_id: light.kitchen_cabinets_left
data_template:
entity_id: light.kitchen_cabinets_coffee
data_template:
mode: restart
I’m using the latest automation/sensors, and for me it is working on turning the lights and setting the brightness, but it’s not working when turning off the lights.
balk77
(Balk77)
December 8, 2021, 6:19pm
10
Hi, just in case somebody bumps into this topic. This is a working code with newer syntax
alias: light 1 --> 2
description: ''
- platform: state
condition:
- condition: template
value_template: >
{{ not is_state_attr('light.light1', 'brightness',
states.light.light2.attributes.brightness ) }}
- choose:
- conditions:
- condition: state
state: 'off'
sequence:
- service: light.turn_off
- conditions:
- condition: state
state: 'on'
sequence:
brightness: '{{ trigger.to_state.attributes.brightness }}'
default: []
mode: single
morilm
(Miguel Morillo)
December 29, 2021, 3:45pm
11
Hi
It’s possible to do it for RBG and Brightness at the same time and on/off… here is the full script
Hope it helps
alias: Sync light
- platform: state
entity_id: light.source
- choose:
- conditions:
- condition: state
state: 'off'
sequence:
entity_id: light.dest
- conditions:
- condition: state
state: 'on'
sequence:
rgb_color: '{{ trigger.to_state.attributes.rgb_color }}'
RayLation
(Ray Lation)
January 27, 2022, 2:51am
12
Or you can simply create 2 entities of type “light switch”, then create an entity of type “light group” with those:
add this to your configuration.yaml:
light: !include lights.yaml
create a lights.yaml file and add this:
- platform: switch
entity_id: switch.officelamp1
- platform: switch
entity_id: switch.officelamp2
- platform: group
entities:
- light.officelamp1
- light.officelamp2
and then just use that new entity “office_all_lights” as a normal light. Both lights will be perfectly in sync.
See doc here:
https://www.home-assistant.io/integrations/light.group/
https://www.home-assistant.io/integrations/light.switch
crlogic
January 27, 2022, 3:22am
13
Template Light > light automations.
Mind was blown when I found out about it.
MBJacobs
(Mike Jacobs)
November 16, 2022, 1:50am
14
This works beautifully. Thank you.
trevor.k
(Trevor)
November 8, 2023, 3:03am
15
Very new to HA… I added this automation to my setup, however, I noticed that if changing the state/brightness via the physical switch there is a very long delay between when the second entity updates. Via HA app is almost instant. Any way to resolve this?
Yben
November 20, 2024, 1:22am
16
I know this is old, but wanted to show my appreciation for this. Works great!
