Setting up UniFi Protect
Just can’t figure out the proper set up. I have been following this help to get my Unifi cameras set up.
I created an admin user locally and was able to manually log into the Protect UNVR console locally using that user so I know that is working.
Unifi and HA all running latest software.
I at at this screen and I continue to get a Failed to Connect. Like others, I have tried Port 443, 7443, 8443 and nothing. Tried both the IP of the NVR and the Cloud Gateway. Tried just IP, Http, Https. Nothing. With Verify SSL on and off (although I don’t have a cert locally installed and Chrome tells me that when I login locally). What am I doing wrong?
fwiw, I’m seeing the same, both for Protect and for Network. I’m assuming the Unifi integration is just broken at the moment?
Any update on this? I’m having the same issue.
