I originally installed through configuration/integration the ZWAVE integration which I understand is 1.4. Install a Aeon Labs Z-stick Gen 5 which went fine. Then wanted to setup a ZW112 Door Window Sensor 6 (AEON Labs) which paired fine except it did not report when the door was closed. Read lots of posts this was a problem under Openwave 1.4 and was fixed in 1.6, so to decided to install Zwave2MQTT as I understand this is on 1.6.974.
Got that installed okay but I still get the same results where it will not report a closed state. Now I did notice something odd. In the control panel the Last Active beside the nodes appears to only be updated the first time a device is added or when a reboot occurs. I also noticed that the battery value of the door/window sensor didn’t update after it was charged. It also shows the device having a status of Sleep.
I am trying to get this all moved over from Smartthings and am trying to get some clarity on how this all works and if I am going down the right path. Hoping someone can help put me in the right direction.
