I try to write a script to mimic the behaviour of a shutter control button to save reimplement it for all my buttons.
Press once down the shutters will close. press again stop the shutters. same for up and open.
The problem I have is, that the variables scope arn’t global.
So following script can’t work.
Is there a way around it by either reading the value of the variable with the name in “var_direction_state” or by some kind of variable with a global scope?
alias: Rollo open-close-stop
description: Toggle between a direction and stop
fields:
cover_id:
required: true
selector:
entity:
domain: cover
direction:
required: true
selector:
select:
options:
- label: Open
value: open
- label: Close
value: close
variables:
open_direction_state: "opening"
open_direction_service: "cover.open_cover"
close_direction_state: "closing"
close_direction_service: "cover.close_cover"
var_direction_state: "{{ direction }}_direction_state"
var_direction_service: "{{ direction }}_direction_service"
sequence:
- choose:
- conditions: "{{ direction == 'close' }}"
sequence:
- variables:
- choose:
- conditions: "{{ states(cover_id) == direction_state }}"
sequence:
- service: cover.stop_cover
data: {}
entity_id: "{{ cover_id }}"
default:
- service: "{{ direction_service }}"
data: {}
