Running latest Home Assistant.
How to make the Z-wave Node Options persistant?
When rebooting hassio all options are back to default.
Options are persistent, but that is device dependent. If you try to set an option and the device is not awake, then nothing will set on the device. Make sure you wake the device before setting options.
