I’m trying to add a second user to my HASS instance. From what I can tell from this post there is supposed to be a ‘Settings’ entry in my HASS menu (on the left) with a gear icon and within that entry are multiple other sub-entries, including a ‘Users’ option. I don’t have the ‘Settings’ entry.
I’m using the Dockerfile homeassistant/home-assistant:0.91.2, but it also was not working with homeassistant/home-assistant:0.91.1.
I have no auth_providers and no http sections.
When I wipe my /config/.storage and start fresh. I can create a new user who is the owner.
grep is_owner persistent/auth
“is_owner”: true,
However, I do not have an entry on the left for ‘Settings’ and thus I cannot figure out how to add another user. /config/.storage/auth* has my initial user definition, but I’m not sure what to edit to add a second user. I wouldn’t know how to choose an ‘id’.
Any thoughts on other settings to check? I feel like this has to be a config error, but I’m not sure where to look. Is this something unique to running HASS as a container?
I think my problem has to do with the fact that I was running ‘frontend:’ and not ‘default_config:’ which seems as though it might configure more than just the frontend.
-# Enables the frontend
-frontend:
+# Configure a default setup of Home Assistant (frontend, api, etc)
+default_config:
I’m still sorting through the changes to my HASS instance after making that change.
