I’m new to HA (just switched from OpenHab) but i try to make an automation rule that starts at a fixed time (5 day’s a week). but if i try to set this up i get an error.
it seems that i didn’t do my configuration very well
what did i wrong?
i missing: Entities !!! but what is this and how can i configure them for a calendar?
You have no calendar set, so it can’t appear. You will need to set for example a Google calendar for that.
Try with this new HA function, which does not need any external calendar:
Nice, i can create a schedule. but how can i use this as a “trigger” or “condition” in the automation?
Hi all,
I’m just moved from OpenHab 3 to HomeAssistant. For the heating of my house I use InfraRed Panels per room and switch then on/of via Z-Wave WallPlugs devices.
What I wanted to do is the following:
Switch them of/on based on a schedule
If the schedule is “on” the "generic_thermostat” should regulate the temperature based on the virtual thermostat. and there is a delay to prevent that all IR-heaters switch on at the same time.
Is wanted to do this via automation as you see below.
But it doesn’t work, meaning that the “generic_thermostat” doesn’t switch off if the schedule is in the state “off”
What could be wrong?
alias: Kantoor_IR-Heater_UIT
description: volgens schema en vertraging 13 seconden
- platform: state
entity_id:
- schedule.kantoor_ir_heater_schedule
to: "off"
condition: []
- delay:
hours: 0
minutes: 0
seconds: 13
milliseconds: 0
- type: turn_off
device_id: a9a2960c8c3cef190737b367f5610c35
entity_id: switch.metered_wall_plug_switch_3
domain: switch
- service: climate.set_hvac_mode
hvac_mode: "off"
area_id: kantoor
mode: single
in the Configuration.yaml i created:
# temp regelingen per ruimte
# Kantoor
climate:
- platform: generic_thermostat
name: Kantoor IR-Heater control
heater: switch.metered_wall_plug_switch_3
target_sensor: sensor.multisensor_6_air_temperature_3
min_temp: 15
max_temp: 22
ac_mode: false
target_temp: 17
cold_tolerance: 0.3
hot_tolerance: 0.3
min_cycle_duration:
seconds: 5
keep_alive:
minutes: 3
initial_hvac_mode: "off"
away_temp: 16
precision: 0.1
I found the solution and as so often it was “simple”.
i forgot the “entry_id”
description: Schakel de kantoor thermostaat UIT volgens schema
- platform: state
entity_id:
to: "off"
condition: []
- delay:
hours: 0
minutes: 0
seconds: 13
milliseconds: 0
entity_id: climate.kantoor_ir_heater_control
hvac_mode: "off"
mode: single
