Setup Development environment on M1 MAC
I am planning to start with some HA Python development. I only have 2 M1 MAC’s and followed the steps and prerequisites described in Set up Development Environment | Home Assistant Developer Docs
I got stock on step 2:
Once your fork is created, copy the URL of your fork and paste it below, then click “Open”:
The error I got state that Docker is not running
[91 ms] Dev Containers 0.292.0 in VS Code 1.78.2 (b3e4e68a0bc097f0ae7907b217c1119af9e03435).
[91 ms] Start: Run: docker version --format {{.Server.APIVersion}}
[195 ms]
[195 ms] Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker daemon running?
Many thanks in advance,
Rien
Have you checked if Docker daemon it’s in fact running in the background?
You can simply run “docker ps” on your terminal to check if docker is running or not.
Hi @Matteo_b
Thanks for your answer.
riendupre@MacMini ~ % docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
Is this what I suppose to see?
Yes, that is correct.
Do you still receive the error?
Yes I do unforotunately
