Hi, I’m still new to this and this is my first try to write a config file for HA.
I’m trying to add my 3d printer (Klipper/Moonraker). I used the original config file from their repo and changed it to fit my setup.
I’m getting this error:
Setup failed for printer: Integration not found.
This is my config file:
- platform: rest
resource: "http://192.168.8.8:7125/printer/objects/query?heater_bed&extruder&print_stats&toolhead&display_status&virtual_sdcard"
json_attributes_path: "$.result.status"
json_attributes:
- heater_bed
- extruder
- print_stats
- toolhead
- display_status
- virtual_sdcard
value_template: >-
{{ 'OK' if ('result' in value_json) else None }}
sensors:
ender3v2_hotend_target:
friendly_name: 'Ender3V2 Hotend Target'
device_class: temperature
unit_of_measurement: '°C'
value_template: >-
{{ states.sensor.Ender3V2_sensor.attributes['extruder']['target'] | float | round(1) if is_state('sensor.Ender3V2_sensor', 'OK') else None }}
ender3v2_hotend_actual:
value_template: >-
{{ states.sensor.Ender3V2_sensor.attributes['extruder']['temperature'] | float | round(1) if is_state('sensor.Ender3V2_sensor', 'OK') else None }}
ender3v2_bed_target:
value_template: >-
{{ states.sensor.Ender3V2_sensor.attributes['heater_bed']['target'] | float | round(1) if is_state('sensor.Ender3V2_sensor', 'OK') else None }}
ender3v2_bed_actual:
value_template: >-
{{ states.sensor.Ender3V2_sensor.attributes['heater_bed']['temperature'] | float | round(1) if is_state('sensor.Ender3V2_sensor', 'OK') else None }}
ender3v2_state:
icon_template: mdi:printer-3d
value_template: >-
{{ states.sensor.Ender3V2_sensor.attributes['print_stats']['state'] if is_state('sensor.Ender3V2_sensor', 'OK') else None }}
ender3v2_current_print:
value_template: >-
{{ states.sensor.Ender3V2_sensor.attributes['print_stats']['filename'] if is_state('sensor.Ender3V2_sensor', 'OK') else None }}
ender3v2_current_progress:
unit_of_measurement: '%'
icon_template: mdi:file-percent
value_template: >-
{{ (states.sensor.Ender3V2_sensor.attributes['display_status']['progress'] * 100) | round(1) if is_state('sensor.Ender3V2_sensor', 'OK') else None }}
ender3v2_print_time:
icon_template: mdi:clock-start
value_template: >-
{{ states.sensor.Ender3V2_sensor.attributes['print_stats']['print_duration'] | timestamp_custom("%H:%M:%S", 0) if is_state('sensor.Ender3V2_sensor', 'OK') else None }}
ender3v2_time_remaining:
icon_template: mdi:clock-end
value_template: >-
{{ (((states.sensor.Ender3V2_sensor.attributes['print_stats']['print_duration'] / states.sensor.Ender3V2_sensor.attributes['display_status']['progress'] - states.sensor.Ender3V2_sensor.attributes['print_stats']['print_duration']) if states.sensor.Ender3V2_sensor.attributes['display_status']['progress'] > 0 else 0) | timestamp_custom('%H:%M:%S', 0)) if is_state('sensor.Ender3V2_sensor', 'OK') else None }}
ender3v2_eta:
icon_template: mdi:clock-outline
value_template: >-
{{ (as_timestamp(now()) + 2 * 60 * 60 + ((states.sensor.Ender3V2_sensor.attributes['print_stats']['print_duration'] / states.sensor.Ender3V2_sensor.attributes['display_status']['progress'] - states.sensor.Ender3V2_sensor.attributes['print_stats']['print_duration']) if states.sensor.Ender3V2_sensor.attributes['display_status']['progress'] > 0 else 0)) | timestamp_custom("%H:%M:%S", 0) if is_state('sensor.Ender3V2_sensor', 'OK') else None }}
ender3v2_nozzletemp:
icon_template: mdi:thermometer
value_template: >-
{{ [(states.sensor.Ender3V2_sensor.attributes['extruder']['temperature'] | float | round(1) | string), " / ", (states.sensor.Ender3V2_sensor.attributes['extruder']['target'] | float | round(1) | string)] | join if is_state('sensor.Ender3V2_sensor', 'OK') else None }}
ender3v2_bedtemp:
value_template: >-
{{ [(states.sensor.Ender3V2_sensor.attributes['heater_bed']['temperature'] | float | round(1) | string), " / ", (states.sensor.Ender3V2_sensor.attributes['heater_bed']['target'] | float | round(1) | string)] | join if is_state('sensor.Ender3V2_sensor', 'OK') else None }}
# MJPEG camera can be exposed to HA
camera:
- platform: mjpeg
still_image_url: http://192.168.8.8/webcam/?action=snapshot
mjpeg_url: http://192.168.8.8/webcam/?action=stream
any help would be appreciated
