Hi everyone!
I haven’t changed anything in my setup for about 4 months, aside from occasionally running regular updates. However, I keep losing custom integrations they randomly break with some updates and then start working again after some updates.
They all show the same error in the logs: Setup failed for custom integration 'xxx': Requirements for goodwe not found: ['xxx']
I have no idea what I should be looking for. These same integrations are working fine on another setup I made for a friend, even though it’s running the exact same version of Home Assistant so there shouldn’t be any issue.
Is there anything I can check to figure out what’s causing the problem? I’ve been ignoring some of the missing integrations, but one of the major ones broke after updating to version 2025.4.1 and I really can’t do without it.
Those custom integrations have no issues like this reported. I have acces to 6 more HA instalations and there is no issue either with them. I am little confused why it break and fixes itself for no apparent reason.
I have found something more in the log, when I restarted. Unable to install package pyuptimekuma-hass: error: Failed to fetch: `https://files.pythonhosted.org/packages/32/d2/d41c3b35a1aa63fefd869dee61ed85390ab46b19579804e62ba85417e8df/pyuptimekuma_hass-0.0.6-py3-none-any.whl.metadata` Caused by: Could not connect, are you offline? Caused by: Request failed after 3 retries Caused by: error sending request for url (https://files.pythonhosted.org/packages/32/d2/d41c3b35a1aa63fefd869dee61ed85390ab46b19579804e62ba85417e8df/pyuptimekuma_hass-0.0.6-py3-none-any.whl.metadata) Caused by: client error (Connect) Caused by: dns error: failed to lookup address information: Name does not resolve Caused by: failed to lookup address information: Name does not resolve Unable to install package cloudscraper: error: Failed to fetch: `https://files.pythonhosted.org/packages/81/97/fc88803a451029688dffd7eb446dc1b529657577aec13aceff1cc9628c5d/cloudscraper-1.2.71-py2.py3-none-any.whl.metadata` Caused by: Could not connect, are you offline? Caused by: Request failed after 3 retries Caused by: error sending request for url (https://files.pythonhosted.org/packages/81/97/fc88803a451029688dffd7eb446dc1b529657577aec13aceff1cc9628c5d/cloudscraper-1.2.71-py2.py3-none-any.whl.metadata) Caused by: client error (Connect) Caused by: dns error: failed to lookup address information: Name does not resolve Caused by: failed to lookup address information: Name does not resolve
I’m having the same issue. After updating the core, some packages fail to load due to missing dependencies. I then have to manually connect to the core container via the console (find the ID using docker ps and then docker exec -it 870d0e1f4177 /bin/sh) and manually run pip install old_package, and then restart Home Assistant. Unfortunately, I don’t have a log at the moment, but it’s quite likely the same issue with “offline”.
The command pip list --outdated shows me dozens of outdated packages… but they probably aren’t old enough to prevent integrations from starting.
