Dear Home Assistant Forum,
I am trying to get HA to read data from an Epever UP-Hi solar inverter/charger using the guide kindly posted by Ucatchmydrift, however i have been at this for weeks and keep hitting a brick wall.
I removed Ucatchmydrift’s config from configuration.yaml until i get no errors in developer tools ‘check configuration’ which leaves me with just the modbus section:
I think i may have resolved this issue, another spacing mistake in the configuration.yaml file. Additional 2 spaces for sensors and all below seems to work, not getting any errors and now seeing the sensor names on the overview screen, but no values, just says ‘unavailable’, still one step further on.
Thanks Finity,
I just blundered across this from looking at a similar configuration.yaml
Could you show me an example of where to use the three back ticks please? I don’t understand yet.
Kind regards
Ade
it’s hard to show because the forum converts backticks into code blocks but:
# three backticks here ```
# put some code here
- platform: something
options:
option_1: something
option_2: something_else
so in your case you put the backticks on the line before “loads default set of…” and on the line after “input_type: input”
