Since the update to 2022.11 zigbee2mqtt is not working anymore. It has always (about a year and a half) worked with this zigbee stick.
I flashed the firmware of the stick to the latest version, changed usb connection and put it back but nothing helped.
In the integrations tab the integration slae.sh cc2652rb stick - slaesh’s iot stuff says: setup failed. Check the logs.
In the log it says :
Logger: homeassistant.config_entries
Source: components/zha/core/gateway.py:172
First occurred: 13:24:49 (1 occurrences)
Last logged: 13:24:49
Error setting up entry slae.sh cc2652rb stick - slaesh’s iot stuff - slae.sh cc2652rb stick - slaesh’s iot stuff for zha
File “/usr/local/lib/python3.10/site-packages/zigpy_znp/api.py”, line 998, in request
response = await response_future
asyncio.exceptions.CancelledError
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 365, in async_setup
result = await component.async_setup_entry(hass, self)
File “/usr/src/homeassistant/homeassistant/components/zha/init.py”, line 112, in async_setup_entry
await zha_gateway.async_initialize()
File “/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py”, line 185, in async_initialize
raise exc
File “/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py”, line 172, in async_initialize
self.application_controller = await app_controller_cls.new(
File “/usr/local/lib/python3.10/site-packages/zigpy/application.py”, line 144, in new
await app.startup(auto_form=auto_form)
File “/usr/local/lib/python3.10/site-packages/zigpy/application.py”, line 124, in startup
await self.connect()
File “/usr/local/lib/python3.10/site-packages/zigpy_znp/zigbee/application.py”, line 106, in connect
await znp.connect()
File “/usr/local/lib/python3.10/site-packages/zigpy_znp/api.py”, line 709, in connect
await self.nvram.determine_alignment()
File “/usr/local/lib/python3.10/site-packages/zigpy_znp/nvram.py”, line 31, in determine_alignment
rsp = await self.znp.request(c.UTIL.AssocFindDevice.Req(Index=0))
File “/usr/local/lib/python3.10/site-packages/zigpy_znp/api.py”, line 994, in request
async with async_timeout.timeout(
File “/usr/local/lib/python3.10/site-packages/async_timeout/init.py”, line 129, in aexit
self._do_exit(exc_type)
File “/usr/local/lib/python3.10/site-packages/async_timeout/init.py”, line 212, in _do_exit
raise asyncio.TimeoutError
asyncio.exceptions.TimeoutError
I am using home assistant on a rpi 4 with ssd.
Home Assistant 2022.11.1
Supervisor 2022.10.2
Operating System 9.3
