I have set up Google Assistant my self via the manual setup and it seems to work ok how ever when I try and stream my cameras (which work through Lovelace) I get the attached screen shot.
Does any one have any suggestion on where to look for a problem ?
Nabu Casa takes care of all of that for you. It is its own service, created much like you did manually. When you set up google through nabu casa, you basically have to log into google and say “I authorize nabu casa to do this on my behalf”.
If you didn’t do that, nabu casa will try to send these requests to google and google will say “this isn’t right? Who are you?”
I’m not sure you can use the manual setup and nabu casa at the same time honestly. I have a feeling things are going to get confused.
Not sure about NGINX… Its certainly not some thing I have made a point of installing.
As far as compatible cameras… They are rtsp and showing in HA fine… But… I wonder I’m not converting them in any way for the chrome cast so I wonder if that’s what I have missed…
