Hello!
I have a Raspberry pi 3b+ and a HomeAssistant 0.92 was installed that worked for about a year. Unfortunately, my SD card failed and I began to reinstall the system version 0.108.1.
I ran into a number of problems:
- I can’t connect Yeelight celling lamp 650 to the color bulb. Previously, these lamps were detected automatically. Writing to the config file also does not help to determine them.
in file configuration.yaml :
light: !include light.yaml
sensor: !include sensors.yaml
in file light.yaml:
- platform: yeelight
devices:
192.168.1.220:
model: ceiling4
transition: 1000
use_music_mode: True
save_on_change: True
- I can’t adjust the display of the battery level in the xiaomi sensors. Earlier, I used the following code but in the new version get an error
in file sensor.yaml:
#sensor:
- platform: attributes
friendly_name: "Batteries"
attribute: battery_level
unit_of_measurement: "%"
entities:
- binary_sensor.wall_switch_both_158d0xxxxxxx
- binary_sensor.cube_158dxxxxxxxx
3.I made several rooms on the main tab: corridor, study, nursery, bedroom, bathroom, living room. After I began to consistently fill these tabs with devices. I was unpleasantly surprised when I reached 4 tabs, because I saw a copy of tab 2 in it. I looked at tab 5 and saw a copy of tab 3 in it. When I try to delete tab 5, I am asked to delete tab 3. If I delete the contents of tab 5 then the contents of tab 3 are also deleted.
In the old version, there was a ui-lovelace.yaml file where you could manually edit the tabs and their contents. In the new version I did not find this. Is this feature removed?
Help me to understand. The system does not work and I do not know what to do.
