Setup more than one switch (MQTT)
I was able to configure one switch to work via MQTT:
switch:
  • platform: mqtt
    command_topic: “cmnd/sonoff-22/POWER”
    state_topic: “stat/sonoff-22/POWER”
    qos: 1
    optimistic: false
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
But I need 7 of these, so I need to understand the syntax to add more devices.
This doesn’t work :frowning:
Thanks for your help
Multi
The problem is described in the screenshot “Bad indentation” (and the correct domain name is switch not switches).
Even if you fix it, you will face another problem because you are using the old, deprecated format for defining MQTT switches. Refer to the examples in the documentation to see the new format.
Example
mqtt:
  switch:
    - unique_id: bedroom_switch
      state_topic: "home/bedroom/switch1"
      command_topic: "home/bedroom/switch1/set"
      availability:
        - topic: "home/bedroom/switch1/available"
      payload_on: "ON"
      payload_off: "OFF"
      state_on: "ON"
      state_off: "OFF"
      optimistic: false
      qos: 0
      retain: true
That change made it for me, now I can add via unique_id more switches.
Thanks,
Multi
