not sure if thats the right place for suchz a question but I want to get the water temperature of our outdoor pool.
Thought about using an esp32 running esphome to integratre into home assistant.
I just want to be sure that this all works out and Im not missing something or if there is another better option out there. It needs to be waterproof (or have a waterproof extension), obviously work with home assistant and best would be wifi because I have not zigbee/z-wave coverage there (but wifi is plenty).
Would appreciate some confirmation/ feedback by you guys as this would be my first “diy” sensor and im also not really familiar with circuits, bread boards and so on…
Yes, those are all the parts you need. Check this out if tou need some inspiration on how to mount the temperature sensor in the pool: Smarter Swimming Pool 2: Water Temperature – neon.ninja
I have since migrated this sensor to ESPHome, but the wiring and mounting is still the same.
ESP with USB-C vs micro USB: Does not make any difference other than the power cable used.
What type of pool do you have? Chlorine I guess? Its salt for me.
Just came into my mind that submerging metal into a salt water pool over a long peroid of time is not such a good idea.
I stumbled upon a different version of the ds18b20 which does not have a metal cap: Amazon.de (SEN-11050 ). Although it is way more expensive
Not sure. I had to replace my sensor once after about 5 years. I think the metal tip is made of stainless steel, so it might survive a salt pool?
That might be a good option as well. It says it’s sealed, so would be interesting to see how long the seal and plastic survives in salt water or chlorine.
For short extensions (like a couple of metres) I have used simple 3-core shielded wire about 20AWG diameter.
I haven’t used RJ45 myself for such extensions, but I remember people on this forum reporting they successfully used RJ45 over longer distances for similar sensors.
