I’m trying to setup ssl such that I can add Z-wave devices using the QR code.
I’ve read quite some docs on this but most use cases are targetting remote access, which I really don’t want.
I tried to setup duckdns and let’s encrypt. After quite some trouble I ended up with:
- a proper let’s encrypt certificate
- duckdns also trying to do lets encrypt and fails the dns challange: failing with Incorrect TXT record "" found at
- a dns which resolves to the public ip of my router and havent found a way to internally reroute the traffic towards my HA
Thus now I can only access HA with tls using the ip adres.
As such the andriod app no longer works, because it does not trust the certificate issued by let’s encrypt.
I don’t want remote access, I do want TLS and I want to add devices to my Zwave controller without setting up proxies, local dns server etc…
Is this possible?
