Nothing is really working and Google Home cannot connect to Hassio.
I have not done anything at all so the previous working yamls shouldnt be any problem.
2018-09-28 16:08:15 WARNING (MainThread) [homeassistant.setup] Setup of mqtt is taking over 10 seconds.
2018-09-28 16:10:13 ERROR (MainThread) [homeassistant.components.mqtt] Failed to connect due to exception: [Errno 110] Operation timed out
2018-09-28 16:10:13 ERROR (MainThread) [homeassistant.setup] Setup failed for mqtt: Component failed to initialize.
2018-09-28 16:10:14 WARNING (MainThread) [homeassistant.loader] You are using a custom component for sensor.hue which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2018-09-28 16:10:14 WARNING (MainThread) [homeassistant.loader] You are using a custom component for sensor.pollenkoll which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2018-09-28 16:10:17 WARNING (MainThread) [homeassistant.loader] You are using a custom component for tts.google which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2018-09-28 16:10:19 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of sensor.mqtt. Setup failed for dependencies: mqtt
2018-09-28 16:10:19 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform sensor.mqtt: Could not set up all dependencies.
2018-09-28 16:10:19 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of alarm_control_panel.manual_mqtt. Setup failed for dependencies: mqtt
2018-09-28 16:10:19 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform alarm_control_panel.manual_mqtt: Could not set up all dependencies.
2018-09-28 16:10:24 WARNING (MainThread) [homeassistant.setup] Setup of input_boolean is taking over 10 seconds.
2018-09-28 16:10:27 WARNING (MainThread) [homeassistant.setup] Setup of group is taking over 10 seconds.
2018-09-28 16:10:27 WARNING (MainThread) [homeassistant.core] Unable to find service group/set
2018-09-28 16:10:32 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of device_tracker.owntracks. Setup failed for dependencies: mqtt
2018-09-28 16:10:32 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform device_tracker.owntracks: Could not set up all dependencies.
2018-09-28 16:12:52 WARNING (MainThread) [homeassistant.components.cloud.iot] Unable to connect: Cannot connect to host cloud.hass.io:8000 ssl:None [Operation timed out]
2018-09-28 16:15:03 WARNING (MainThread) [homeassistant.components.cloud.iot] Unable to connect: Cannot connect to host cloud.hass.io:8000 ssl:None [Operation timed out]
2018-09-28 16:17:17 WARNING (MainThread) [homeassistant.components.cloud.iot] Unable to connect: Cannot connect to host cloud.hass.io:8000 ssl:None [Operation timed out]
2018-09-28 16:19:34 WARNING (MainThread) [homeassistant.components.cloud.iot] Unable to connect: Cannot connect to host cloud.hass.io:8000 ssl:None [Operation timed out]
2018-09-28 16:22:00 WARNING (MainThread) [homeassistant.components.cloud.iot] Unable to connect: Cannot connect to host cloud.hass.io:8000 ssl:None [Operation timed out]
2018-09-28 16:24:41 WARNING (MainThread) [homeassistant.components.cloud.iot] Unable to connect: Cannot connect to host cloud.hass.io:8000 ssl:None [Operation timed out]
2018-09-28 16:27:55 WARNING (MainThread) [homeassistant.components.cloud.iot] Unable to connect: Cannot connect to host cloud.hass.io:8000 ssl:None [Operation timed out]
2018-09-28 16:31:43 ERROR (Thread-10) [pychromecast.socket_client] Error reading from socket.
2018-09-28 16:31:43 WARNING (Thread-10) [pychromecast.socket_client] Error communicating with socket, resetting connection
2018-09-28 16:31:43 ERROR (Thread-10) [pychromecast.socket_client] Failed to connect, retrying in 2.0s
2018-09-28 16:31:47 ERROR (Thread-10) [pychromecast.socket_client] Failed to connect. No retries.
2018-09-28 16:32:13 WARNING (MainThread) [homeassistant.components.cloud.iot] Unable to connect: Cannot connect to host cloud.hass.io:8000 ssl:None [Operation timed out]
2018-09-28 16:32:59 ERROR (Thread-15) [pychromecast.socket_client] Error reading from socket.
2018-09-28 16:32:59 WARNING (Thread-15) [pychromecast.socket_client] Error communicating with socket, resetting connection
2018-09-28 16:32:59 ERROR (Thread-15) [pychromecast.socket_client] Failed to connect, retrying in 2.0s
2018-09-28 16:33:03 ERROR (Thread-15) [pychromecast.socket_client] Failed to connect. No retries.
2018-09-28 16:38:38 WARNING (MainThread) [homeassistant.components.cloud.iot] Unable to connect: Cannot connect to host cloud.hass.io:8000 ssl:None [Operation timed out]
2018-09-28 16:49:20 WARNING (MainThread) [homeassistant.components.cloud.iot] Unable to connect: Cannot connect to host cloud.hass.io:8000 ssl:None [Operation timed out]
2018-09-28 17:00:01 WARNING (MainThread) [homeassistant.components.cloud.iot] Unable to connect: Cannot connect to host cloud.hass.io:8000 ssl:None [Operation timed out]
2018-09-28 17:00:44 ERROR (Thread-16) [pychromecast.socket_client] Error reading from socket.
2018-09-28 17:00:44 WARNING (Thread-16) [pychromecast.socket_client] Error communicating with socket, resetting connection
2018-09-28 17:00:44 ERROR (Thread-16) [pychromecast.socket_client] Failed to connect, retrying in 2.0s
2018-09-28 17:00:48 ERROR (Thread-16) [pychromecast.socket_client] Failed to connect. No retries.
