Several issues (no connection at all, root pw, unresponsiveness
Been having several issues of late.
1) My immediate problem is that my RPI 3 seems to not connect to the network after rebooting it yesterday. I can login to the CLI directly on the Pi via keyboard and mouse. docker addresses look good but host_internet and supevisor_internet both say “false” and eth0 has no IPs. Everything (Core, Supervisor, etc) is on the latest as I tend to keep everything updated. I tried enabling wifi but i get “unexpected server response”
I tried a different ethernet cable and now the IP info is correct but still not working. Also curiously, trying to log in directly on the device says “Home assistant CLI is not running. Jump into emergency and console” and I guess i’m at a regular CLI interface.
Forget issue 1. Was not specific to this device
  1. Root password via SSH is sometimes not accepted in a SSH or download client. The only way to fix it is to use the Terminal add-on within HA to ‘passwd’ (i’m not prompted to login there)
  2. The entire device becomes unresponsive after a day or two. I’m trying to eliminate potential culprits but it’s hard to troubleshoot when logs are wiped on startup
Note: this install started life on a microSD but I set up SSD booting and restored the image to it about a month ago. The third issue has been happening for months.
Any help is appreciated. I can try to get further stats/details if needed but i’m concerned i may have to start over and i wasn’t quite ready for that yet.
Do you have custom components installed ? If so, disable one by one and see if the situation improves. It might be a memory leak somewhere.
I’ve got a bunch. I removed a few that aren’t being used but it seems to be still happening. Is it enough to disable the integrations that use them (such as alexa media player, ical/ics, etc)?
