Just installed the Home Assistant OS on an old PI (Pi3).
I was trying to configure WiFi, so I installed SSH and went to the terminal and looked for the network.d directory, or wpa_supplicant. Couldn’t find anything, installed wpa_supplicant - then was not sure how to shutdown to do a reboot. I picked (I think) shutdown server.
Now there is no web-page. How do I restart it? Fortunately I can still git in with the SSH. But I have no idea what command to run to start the server back up - I thought it would be automatic. Can I make it automatic?
As this post is in the Home Assistant OS category I assume you installed either a supervised install or Home Assistant OS image. So you can set up networking from the GUI.
Go to the Supervisor Page, System Tab, then look at the Host Card on that page. Click on the Change button next to your IP address.
I’ll also echo what Nick said.
Wifi is ok if you are just doing a bit of testing but not a good idea for a production server.
Changing to port 80 is also not a good idea. Keep your system as stock standard as possible to aid in future troubleshooting.
| | | | /\ (_) | | | |
| |__| | ___ _ __ ___ ___ / \ ___ ___ _ ___| |_ __ _ _ __ | |_
| __ |/ _ \| '_ \ _ \ / _ \ / /\ \ / __/ __| / __| __/ _\ | '_ \| __|
| | | | (_) | | | | | | __/ / ____ \\__ \__ \ \__ \ || (_| | | | | |_
|_| |_|\___/|_| |_| |_|\___| /_/ \_\___/___/_|___/\__\__,_|_| |_|\__|
Welcome to the Home Assistant command line.
System information
IPv4 addresses for eth0: 192.168.1.100/24
IPv6 addresses for eth0: 2600:1700:66c2:4810:93f3:19b1:9b4e:9de4/64, 2600:1700:66c2:4810::44e/128, fe80::8dad:883a:242b:cee5/64
IPv4 addresses for wlan0:
OS Version: Home Assistant OS 5.13
Home Assistant Core: 2021.4.6
Home Assistant URL: http://homeassistant.local:8123
Observer URL: http://homeassistant.local:4357
➜ ~ ha core info
arch: armv7
audio_input: None
audio_output: None
boot: true
image: homeassistant/raspberrypi3-homeassistant
ip_address: 172.30.32.1
last_version: 2021.4.4
machine: raspberrypi3
port: 8123
ssl: false
update_available: true
version: 2021.4.6
version_latest: 2021.4.4
wait_boot: 600
watchdog: true
➜ ~ ha supervisor info
addons:
- description: Expose Home Assistant folders with SMB/CIFS
icon: true
logo: true
repository: core
slug: core_samba
state: unknown
update_available: false
version: 9.3.1
version_latest: 9.3.1
- description: ESPHome Hass.io add-on for intelligently managing all your ESP8266/ESP32
devices.
icon: true
logo: true
repository: a0d7b954
slug: a0d7b954_esphome
state: unknown
version: 1.16.2
version_latest: 1.16.2
- description: The Android Debug Bridge server program
icon: true
logo: true
name: ADB - Android Debug Bridge
slug: a0d7b954_adb
state: unknown
version: 0.8.0
version_latest: 0.8.0
- description: Simple browser-based file editor for Home Assistant
icon: true
logo: true
repository: core
slug: core_configurator
state: started
version: 5.2.0
version_latest: 5.3.0
- description: SSH & Web Terminal access to your Home Assistant instance
icon: true
logo: true
name: SSH & Web Terminal
slug: a0d7b954_ssh
state: started
version: 8.2.0
version_latest: 8.2.0
- description: Check current Home Assistant configuration against a new version
icon: true
logo: true
name: Check Home Assistant configuration
repository: core
slug: core_check_config
state: unknown
version: 3.6.0
version_latest: 3.6.0
addons_repositories:
- https://github.com/hassio-addons/repository
arch: armv7
channel: stable
content_trust: true
debug: false
debug_block: false
diagnostics: false
force_security: false
healthy: true
ip_address: 172.30.32.2
logging: info
supported: true
timezone: America/Chicago
version: 2021.04.0
version_latest: 2021.03.9
wait_boot: 5
The odd thing is, it says it’s IP address is 172.30.32.1. But that address does not respond to a ping, and I don’t think is allowed on my network. The SSH is at 192.168.1.100.
I suppose you are wired at the moment. Go to http://192.168.1.100:8123 you should be able to get into your GUI.
(Let’s forget 172.30.32.1 for a moment. That’s a HAOS internal thing - the core is inside a docker environment and those dockers are all under 172.30.xx.xx)
In the case where your GUI would not let you setup wifi, use nmcli from your SSH shell
It is currently wired. I only wanted to setup the WiFi for when I sometimes have to pull the cable to use on other things. Happens sometimes, I will eventually mount it in the basement next to the router.
