I thought I would share this recent discovery of mine - securely and interactive transfer of files using SFTP. SFTP (SSH File Transfer Protocol) allows transfer of files (e.g. to/from a pi) over SSH. This has the advantage over using a Samba share that you don’t need to be on the same network as the Pi. Also I have found samba share to be a bit of a headache on occasion, and there is the initial setup of samba is tedious. However SFTP is rock solid and very straightforward - if you can SSH to the pi then you can use SFTP. Checkout the raspberry pi docs on SFTP here. Screenshot of Filezilla below.
Cheers
scp is another (related) option, stands for secure copy. Also suns over ssh.
It is but I can’t get scp to work if I’m connecting to the ssh addon container - it only works over sftp… If you ssh to the host then scp works fine.
I tried SFTP, couldn’t get it to work. It turns out the default configuration is “sftp”: false.
But changing that to true gave me an error. Reading further, I found this:
Option ssh : username
This option allows you to change to username the use when you log in via SSH. It is only utilized for the authentication; you will be the root user after you have authenticated. Using root as the username is possible, but not recommended.
Note : Due to limitations, you will need to set this option to root in order to be able to enable the SFTP capabilities.
Here’s the documentation where I found the above:
You are confusing hassos with a real operating system. This thread is not about hassos.
Yes you need to enable compatibility mode, SFTP to true and use root as the user.
