Skippy
(Martin Buist)
1
I have a sh command that I want to run on the router when needed.
All is working if I open a terminal inside hassio ( termnal add-on) and run the command
ssh [email protected] “/bin/vbash -ic ‘restart igmp-proxy’”
When firing the shell_command it is not working
Running it in a cli it works. Running it in shell_command I wil get an error in the log 255 and with some command 127
This is what I did
Whoami -> root
ssh-keygen -t rsa
ssh-copy-id [email protected]
sudo -u hassio -H -s
Whoami -> hassio
ssh-keygen -t rsa
I tried the following commands into my shell_command.yaml. Just to see if any of them work. but none of them does
reset_tv: ssh [email protected] "/bin/vbash -ic 'restart igmp-proxy'"
reset_tv1: ssh -o 'StrictHostKeyChecking=no' [email protected] "/bin/vbash -ic 'restart igmp-proxy'"
reset_tv2: sudo -u hassio -H -s ssh [email protected] "/bin/vbash -ic 'restart igmp-proxy'"
reset_tv3: ssh -i ~/.ssh/id_rsa -o 'StrictHostKeyChecking=no' [email protected] "/bin/vbash -ic 'restart igmp-proxy'"
reset_tv4: sudo -u hassio -H ssh -i /home/hassio/.ssh/id_rsa -o 'StrictHostKeyChecking=no' [email protected] "/bin/vbash -ic 'restart igmp-proxy'"
Tinkerer
(aka DubhAd on GitHub)
3
Taking them one at a time:
Won’t work, because you don’t specify the key file, and because it’ll prompt about accepting the remote host’s key (and you’ll never get the prompt)
Won’t work, because there’s no sudo
command (and also as above)
Won’t work, because the key file isn’t in /root/.ssh/id_rsa
inside the HA container
and the key file isn’t there.
So, how do you solve this? "Easy"
- Create the key file with no passphrase
- Store the key file somewhere under
/config/
- I suggest you create a folder for them in there (eg /config/ssh/
- Specify the full path to the key file
- Tell SSH to accept new keys
Like this:
ssh -i /config/ssh/id_ed25519 -o StrictHostKeyChecking=accept-new [email protected] "/bin/vbash -ic 'restart igmp-proxy'
Skippy
(Martin Buist)
4
Thank you for your explenation. It is very clear now
So I copied all that is in /home/hassio/.ssh/ to the /config/keys
and changed the command
ssh [email protected] -i /config/keys/id_rsa -o StrictHostKeyChecking=accept-new "/bin/vbash -ic 'restart igmp-proxy'"'
Restarted Hassio and now all is working
