SHA5316 CCT LED Light Panel Integration
I have some SHA5316 ENER-J light panels, 60x60cm with CCT dimming.
The controller it comes with seems to have a tiny ESP chip on it, but very little in the way of potential pin-pads to connect a programmer to. I assume there is likely no OTA capability on this? It seems to only work with their app but claims Alexa/Google Home compatibility.
Anyone else had success getting something like this working?
Can anyone suggest alternative LED drivers that support ESPhome or Zigbee with 40W CCT dimming outputs (I think its 36V PSU?) run from mains, UK.
Thanks,
Ben
Well here is the info on the chip TYWE2S Module Datasheet-Tuya IoT Development Platform-Tuya Developer
Thanks, I did find this but wasn’t sure yet if I can access those pins as I think they are on the side facing the capacitor. As I have so many todo I was hoping too for a non-solder method.
I suppose question 1 really is; has anyone found a way to flash these via OTA or Tuyaconvert or something - via the ENERJ app or directly, etc.
Thanks,
Ben
