[Share] Advanced Dashboard Card for SMLIGHT SLZB
Hello everyone!
I recently upgraded my Zigbee coordinator from a Conbee II to a dual-protocol system using an SMLIGHT SLZB (-MR4U for me).
I needed a dedicated card to clearly visualize and monitor all entities related to this device in my Homelab dashboard. Since I couldn’t find a comprehensive solution on the forums, I decided to build my own:
I designed it to be as dynamic as possible. Here is a breakdown of the features:
1. Header & Connectivity Status
  • Identity: Displays the specific model name.
  • Connection Mode: Dynamically shows if the device is communicating via Ethernet or Wi-Fi.
  • Internet Status: A binary check displays “Internet OK” or “Local”.
  • Visual Indicator: The router icon turns Green when the network is up, and Red otherwise.
2. Quick Status Bar (Chips)
  • Chip Modes: Real-time display of active protocols on Chip 1 (EFR32) and Chip 2 (CC2652) (e.g., Coordinator, Thread, Router).
  • Uptime: Calculates how many days and hours the system has been running since the last reboot.
  • VPN Status: Shows if the secure tunnel is active with color coding (Blue/Grey).
3. Thermal Monitoring (Triple Core)
  • Time Visualization: A mini-graph-card displays the 24-hour history for all three components.
  • Detailed Chips: Three individual cards show precise temperatures for the ESP32 (Core), Zigbee/Thread Chip 1, and Zigbee/Thread Chip 2. Card names change dynamically based on the current protocol in use.
4. Memory & Storage Management
  • FileSystem Usage: Monitors flash memory occupancy (system files).
  • Memory Usage: Displays RAM usage in kilobytes (kB).
  • Load Graph: Helps visually detect potential memory leaks or saturated storage.
5. Maintenance Center & Actions
  • Smart Updates: Three conditional blocks appear only when a new firmware is available for the Core or radio chips, offering a direct “Install” button. (Note: Behavior to be confirmed with the next firmware release).
  • Hardware Controls:
    • Reset SLZB-MR4U: Full device reboot (Hard Reset).
    • Reset Radio: Software restart of communication chips without dropping the network connection.
    • Flash Mode: Toggles chips into programming mode (requires confirmation).
  • Comfort Settings: LED Night Mode management, total LED toggle, and Zigbee firmware auto-update toggle.
This card can be easily adapted whether you have a single-chip or a multi-protocol model.
Required Frontend Integrations (HACS):
To make this card work, you will need the following custom cards installed:
  • stack-in-card: To group everything into a single seamless block.
  • mushroom-cards: For the overall aesthetic (Template, Chips, Update cards).
  • mini-graph-card: For the temperature and memory history graphs.
  • config-template-card: Crucial. This allows the use of JavaScript (${...}) to render dynamic chip names within the graphs.
  • card-mod (Optional but recommended): For fine-tuning margins or colors.
The YAML Code:
type: custom:config-template-card
entities:
  - sensor.slzb_mr4u_zigbee_type
  - sensor.slzb_mr4u_zigbee_type_2
card:
  type: custom:stack-in-card
  cards:
      primary: SLZB-MR4U
      secondary: >
        mode: {{ states('sensor.slzb_mr4u_connection_mode') }} |  {{ 'Internet
        OK' if is_state('binary_sensor.slzb_mr4u_internet', 'on') else 'Local'
      icon: mdi:router-wireless
      icon_color: >
        {{ 'green' if is_state('binary_sensor.slzb_mr4u_ethernet', 'on') or
        is_state('binary_sensor.slzb_mr4u_wi_fi', 'on') else 'red' }}
      fill_container: true
    - type: custom:mushroom-chips-card
      chips:
        - type: template
          icon: mdi:antenna
          content: "EFR32: {{ states('sensor.slzb_mr4u_zigbee_type') }}"
          icon_color: "#0051FF"
        - type: template
          icon: mdi:antenna
          content: "CC26: {{ states('sensor.slzb_mr4u_zigbee_type_2') }}"
          icon_color: amber
        - type: template
          icon: mdi:clock-outline
          content: >
            {% set uptime = states('sensor.slzb_mr4u_core_uptime') %}  {% if
            uptime not in ['unknown', 'unavailable', 'none'] %}
              {% set delta = now() - as_datetime(uptime) %}
              {{ delta.days }}j {{ (delta.seconds // 3600) }}h
            {% else %} ??? {% endif %}
        - type: template
          icon: mdi:vpn
          content: "VPN: {{states('binary_sensor.slzb_mr4u_vpn')}}"
          icon_color: >-
            {{ 'blue' if is_state('binary_sensor.slzb_mr4u_vpn', 'on') else
            'grey' }}
      alignment: center
    - type: custom:mushroom-title-card
      subtitle: Temperature
    - type: horizontal-stack
      cards:
          entity: sensor.slzb_mr4u_temperature_de_la_puce_principale
          primary: Core SLZB-MR4U
          secondary: "{{ states(entity) }} °C"
          icon: mdi:thermometer
          icon_color: "#ECFA8E"
          tap_action:
            action: more-info
          entity: sensor.slzb_mr4u_temperature_de_la_puce_zigbee
          primary: Temp. {{ states('sensor.slzb_mr4u_zigbee_type') }}
          tap_action:
            action: more-info
          entity: sensor.slzb_mr4u_temperature_de_la_puce_zigbee_2
          primary: Temp. {{ states('sensor.slzb_mr4u_zigbee_type_2') }}
          icon_color: "#FFC107"
          tap_action:
            action: more-info
    - type: custom:mini-graph-card
      entities:
        - entity: sensor.slzb_mr4u_temperature_de_la_puce_principale
          color: "#ECFA8E"
        - entity: sensor.slzb_mr4u_temperature_de_la_puce_zigbee
          color: "#0051FF"
        - entity: sensor.slzb_mr4u_temperature_de_la_puce_zigbee_2
          color: "#FFC107"
      line_width: 2
      height: 60
      hours_to_show: 24
      align_state: left
      show:
        icon: false
        legend: true
        state: false
      subtitle: Memory
      cards:
          entity: sensor.slzb_mr4u_filesystem_usage
          primary: FileSystem Usage
          secondary: "{{ states('sensor.slzb_mr4u_filesystem_usage') }} kB"
          icon: mdi:harddisk
          icon_color: "#3498db"
          tap_action:
            action: more-info
          entity: sensor.slzb_mr4u_utilisation_de_la_memoire
          primary: Utilisation Mémoire
          secondary: "{{ states('sensor.slzb_mr4u_utilisation_de_la_memoire') }} kB"
          icon: mdi:database
          icon_color: "#9b59b6"
          tap_action:
            action: more-info
      entities:
        - entity: sensor.slzb_mr4u_filesystem_usage
          color: "#3498db"
        - entity: sensor.slzb_mr4u_utilisation_de_la_memoire
          color: "#9b59b6"
      line_width: 2
      height: 40
      hours_to_show: 24
      align_state: left
      show:
        icon: false
        legend: false
        state: false
      subtitle: Action
    - type: conditional
      conditions:
        - entity: update.slzb_mr4u_core_firmware
          state: "on"
      card:
        type: custom:mushroom-update-card
        show_buttons_control: true
    - type: conditional
      conditions:
        - entity: update.slzb_mr4u_zigbee_firmware
          state: "on"
      card:
        name: MAJ {states['sensor.slzb_mr4u_zigbee_type'].state}
    - type: conditional
      conditions:
        - entity: update.slzb_mr4u_zigbee_firmware_2
          state: "on"
      card:
        name: MAJ {states['sensor.slzb_mr4u_zigbee_type_2'].state}
      cards:
          primary: Reset SLZB-MR4U
          icon: mdi:cog-refresh
          icon_color: red
          layout: vertical
          tap_action:
            action: call-service
            service: button.press
              entity_id: button.slzb_mr4u_core_restart
          primary: Reset Radio
          icon: mdi:wifi-refresh
          icon_color: amber
          layout: vertical
          tap_action:
              entity_id: button.slzb_mr4u_zigbee_restart
          primary: Flash Mode
          icon: mdi:memory-arrow-down
          icon_color: blue
          layout: vertical
          tap_action:
              entity_id: button.slzb_mr4u_zigbee_flash_mode
      cards:
        - type: custom:mushroom-entity-card
          entity: switch.slzb_mr4u_led_night_mode
          entity: switch.slzb_mr4u_disable_leds
          entity: switch.slzb_mr4u_auto_zigbee_update
          icon: mdi:refresh-auto
This is my very first post!
I am open to suggestions and eager to improve, so please don’t hesitate to share your feedback, ideas for further enhancements, or even your own versions of this card.
I look forward to seeing how you use it!
UPDATE 2026-01-21
I’ve finally been able to live-test the firmware update notifications. This allowed me to refine the ACTION section with several improvements:
  • UI/UX Polishing: Improved layout for update alerts (Core and Radio chips).
  • Quick Access: Added a direct link to the device’s local web panel for easier maintenance.
  • Multi-language Support: The GitHub repository now features documentation in English :uk:, French :fr:, and Italian :it:.
All fixes and the updated YAML code are now live on the project page:
I have SLZB-MR5U now and I’m trying your dashboard, but with no success. I have such misconfiguration maybe. I have components installed with HACS, with no changes to configuration.yaml. Is this correct or no? HA 2026.3.0. Thanks
same here no success
ok finally got it to work after update to Stack in card. Two things that are not working: Time and the first section under actions
I found problem on my side, elements has different names (Czech), and many elements doesn’t exists for SLZB-MR5U. So code is unusable for me. I hope that in future versions these elements will be added for this device too.
Hi Farberm,
Could you please share your view in order to try help you with your integration ?
Best regards
Hi VPA,
Could you please share with us the entities not provided with your SM Device ?
Regards,
First row in the Action section about formware now showing. I have included screenshot alone with code.
      subtitle: Action
    - type: conditional
      conditions:
        - entity: update.slzb_mr5u_core_firmware
          state: "on"
      card:
        name: MAJ Système (Core)
        layout: horizontal
    - type: conditional
      conditions:
        - entity: update.slzb_mr5u_zigbee_firmware
          state: "on"
      card:
        name: ${'Chip EFR32 (' + states['sensor.slzb_mr5u_zigbee_type'].state + ')'}
        layout: horizontal
    - type: conditional
      conditions:
        - entity: update.slzb_mr5u_zigbee_firmware_2
          state: "on"
      card:
          ${'MAJ Puce CC26 (' + states['sensor.slzb_mr5u_zigbee_type_2'].state +
        layout: horizontal
@eTim
Would this work with my SLZB-MR3 with Firmware: core: v3.2.7 / zigbee: 20251218 ?
Hi eTim, entities has been disabled. But still no success configuring custom cards, so I don’t see anything, only one empty line.
Hi @farberm, I try to check this on Saturday
Hi @Kayut,
Yes it should be, MR3 and MR4 seems pretty similar.
Did you try to implement it ?
Could you share your returns ?
Hi @vpa,
Could you share a capture of the entities provided by your SLZB integration in HA ?
You have to substitute your real sensors, especially in the custom:mini-graph-card section, otherwise everything will be black.
original code.
I added a virtual sensor for testing.
And you need to enable the sensors that are disabled in your SLZB
Hi Tim,
Just wanted to chip in since I am also having a MR3 and just implemented your card after seeing the post.
I already have all of the prerequisites so it was much easier to install. After I pasted the yaml into a manual card, I followed the instructions to replace all the “mr4u” with “mr3”. Unfortunately that was not enough as I could see quite a number of things did not show their value or the label looks wierd. When I went through the code, i realized some of those entities names were in a different language (eg. temp sensors) which I then corrected. I have to also enable a few entities which were disabled (eg. VPN, Wifi, filesystem, etc.). I also changed some of the labels to English. Below is how my MR3 dashboard is looking :wink: Thanks a lot for making this available!
