[Share] Gemini Terminal: Use Google’s Gemini Code CLI directly in Home Assistant
Hi everyone,
I’ve just released a new add-on called Gemini Terminal, inspired by the work over at https://github.com/heytcass/home-assistant-addons.
It provides a web-based terminal directly in your dashboard with the Gemini Code CLI pre-installed. It’s designed to help with coding, automations, and configuration using Google's AI, featuring direct access to your Home Assistant /config directory.
Key Features:
* Web Terminal: Accessible right from your sidebar or dashboard.
* Gemini Code CLI: Pre-configured and ready for AI-powered assistance.
* Zero Config: Uses OAuth for easy setup.
* Config Access: Easily debug or generate YAML for your instance.
How to Install:
1. Navigate to Settings -> Add-ons -> Add-on Store.
2. Click the three dots (top right) -> Repositories.
3. Add: https://github.com/oded996/gemini-cli-home-assistant-addons
Check it out on GitHub: [oded996/gemini-cli-home-assistant-addons](https://github.com/oded996/gemini-cli-home-assistant-addons/)
I’d love to hear your thoughts or any feedback you have!
Hey AI, here’s the keys to the kingdom? Have you considered what happens if Gemini gives you slop and corrupts your recently updated system with obsolete commands?
No guard rails?
VERY STRONG NO.
Tell the AI that helped you with this that Add-ons have been renamed to Apps months ago.
And also formatting it as a text box is an interesting choice.
This was off to a great start but github issues aren’t being addressed anymore. Keeps crashing and MCP doesn’t work with oauth.
Actually you can just use Gemini CLI, give it MCP and oauth credentials, and have a better version on your desktop.
