Share your Themes
I looked through the themes used in the markup and found quite a number that weren’t stated above. There are some areas of the UI that unfortunately “over” use some instead of having their own areas (similar to how sidebar was set up). There are a few other items that use the same identifier for both foreground and background items making it more difficult to really theme completely. Here is a night theme that works pretty well, as well as a template for creating themes. (Set all to fuchsia, and then theme through as you see fit.) You can also set app drawer width, etc… I left out the opacity as it doesn’t seem complete in its use. From what I can tell, anything with - in the name is for internal use.
Many of them have fall backs, which allows you do change a few and get “most” of the UI. Love the capability (thank you whoever did it) and recommend we do a consistency cleanup to really give of power / control over the UI. (For instance, many areas are hard coded with google-red…or have inconsistent items like primary-text-color and text-primary-color)
Here is a pretty complete version of a night view. If you see Juan’s youtube addition, you can jump back and forth with some simple automation. (included at the bottom)
ThemeNighttime:
  # App Styles
  app-drawer-layout-content-transition: none
  app-drawer-width: 265px
  app-drawer-scrim-background: rgba(0, 0, 0, 0.5)
  app-toolbar-font-size: 20px
  # Primary Colors
  primary-text-color: '#cccccc'                  # app-toolbar, badge letter
  secondary-text-color: '#969696'
  disabled-text-color: '#646465'
  primary-background-color: '#1e1e1e'            # app-toolbar
  secondary-background-color: '#252526'          # more info header
  light-primary-color: '#252526'                 # badge background
  accent-color: '#cccccc'
  error-color: 'red'
  primary-color: '#252526'                       # Header bar background
  text-primary-color: '#cccccc'                  # Header bar falls back to white
  dark-primary-color: '#646465'
  # Dialogs
  paper-dialog-color: '#cccccc'                  # Falls back to primary-text-color
  paper-dialog-button-color: '#1e1e1e'           # Falls back to primary-color
  paper-dialog-background-color: '#1e1e1e'       # Falls back to primary-background-color
  # Sidebar
  sidebar-text-color: '#adadad'
  sidebar-icon-color: '#adadad'
  sidebar-selected-text-color: '#ffffff'
  sidebar-selected-icon-color: '#ffffff'
  sidebar-background-color: '#252526'            # Falls back to primary-background-color
  # Dividers
  divider-color: '#616162'
  # Items
  paper-item-min-height: 48px
  paper-item-selected-weight: bold
  paper-item-disabled-color: '#646465'           # Falls back to disabled-text-color
  paper-item-icon-active-color: '#ffe680'        # Falls back to #fdd835
  paper-item-icon-width: 56px
  paper-item-icon-color: '#5696d6'               # Falls back to #44739e
  # Icons
  paper-icon-button-ink-color: '#5696d6'         # Falls back to primary-text-color
  paper-icon-button-disabled-text: '#646465'     # Falls back to disabled-text-color
  paper-icon-button-active-color: 'fuchsia'      # Falls back to primary-color
  paper-icon-button-inactive-color: 'fuchsia'    # Falls back to primary-text-color
  # Toggles
  paper-toggle-button-invalid-ink-color: '#5696d6' # Falls back to error-color
  paper-toggle-button-invalid-button-color: 'fuchsia' # Falls back to error-color
  paper-toggle-button-invalid-bar-color: 'fuchsia' # Falls back to error-color
  paper-toggle-button-label-color: 'fuchsia'  # Falls back to primary-text-color
  paper-toggle-button-checked-bar-color: '#7f9340' # Fall back to primary-color
  paper-toggle-button-checked-button-color: '#ffe680' # Falls back to primary-color
  paper-toggle-button-checked-ink-color: '#5696d6' # Falls back to primary-color
  paper-toggle-button-unchecked-ink-color: '#5696d6'  # Falls back to primary-text-color
  paper-toggle-button-unchecked-button-color: '#1e1e1e' # Falls back to paper-grey-50
  paper-toggle-button-unchecked-bar-color: '#404040'  # Falls back to #000000
  # Tabs
  paper-tab-ink: '#5696d6'                       # Falls back to paper-yellow-a100
  paper-tabs-selection-bar-color: '#5696d6'      # Falls back to text-primary-color
  # Listbox
  paper-listbox-color: '#cccccc'                 # Falls back to primary-text-color
  paper-listbox-background-color: '#252526'      # Falls back to primary-background-color
  # Cards
  paper-card-header-color: '#cccccc'             # Falls back to black
  paper-card-background-color: '#252526'         # Falls back to white
  # States
  state-icon-unavailable-color: 'fuchsia'
  # Toast
  paper-toast-background-color: '#1e1e1e'        # Falls back to #323232
  paper-toast-color: '#cccccc'                   # Falls back to #f1f1f1
Code to automatically switch…
- alias: Home Assistant Set Theme At Startup
  hide_entity: true
  initial_state: true
  - platform: homeassistant
    event: start
  - platform: state
    entity_id: sun.sun
    to: above_horizon
  - platform: state
    entity_id: sun.sun
    to: below_horizon
    service: frontend.set_theme
    data_template:
        {% if states.sun.sun.state == "above_horizon" %}
          default
        {% else %}
          ThemeNighttime
        {% endif %}
But when page is still open on tablet the automatical work automaticaly ?ANd page auto refresh when theme change to night version ?
Great question. I haven’t tried it. (My kiosk HW is coming in the mail) I do know that if you call reload_themes it will refresh automatically (did that a lot of times as I replaced elements and made the service call), so I assume set_theme will work in the same way. (Short answer, I believe so)
Like this theme but has the same problem I ran into with the states page when trying other dark themes and/or trying to modify them to my liking; text is unreadable:
Also you can’t see the ‘pointer’ on an input_number
I might try to find the right element to adjust…
Otherwise I like this theme.
Hi Chrisw - That is one of the items that I mentioned that is buggy in the current markup. Unfortunately, they use “primary-color” instead of “primary-text-color” for the text in the states view.
Hi klogg - Yes, I haven’t had the need for input_number yet. Here is the solution to that. One thing to note: the sliders have primary and secondary coloring allowing you to show how far off left or right you are from the default. I went ahead and applied consistent coloring, but it is an option.
  # Slider
  paper-slider-bar-color: transparent            # Falls back to transparent
  paper-slider-container-color: '#5696d6'        # Falls back to paper-grey-400
  paper-slider-font-color: '#cccccc'             # Falls back to white
  paper-slider-knob-color: '#1e1e1e'             # Falls back to google-blue-700
  paper-slider-active-color: '#5696d6'           # Falls back to google-blue-700
  paper-slider-secondary-color: '#5696d6'        # Falls back to google-blue-300
  paper-slider-disabled-active-color: '#646465'  # Falls back to paper-grey-400
  paper-slider-disabled-secondary-color: '#646465'  # Falls back to paper-grey-400
  paper-slider-height: 2px                       # Falls back to 2px
NightSlider
Opened issue on text…
Text color in States UI (LoveLace) uses ‘primary-color’ instead of ‘primary-text-color’ #2709
Link? I can’t find it under issues. I want to follow it :slight_smile:
https://github.com/home-assistant/home-assistant-polymer/issues/2709
Dark - blue:
      ### Main Interface Colors ###
      primary-color: "#0337a0"
      light-primary-color: "#49adff"
      primary-background-color: "#000000"
      secondary-background-color: var(--primary-background-color)
      divider-color: "#2D2D2D"
      ### Text ###
      primary-text-color: "#e3e6e8"
      secondary-text-color: "#0337a0"
      text-primary-color: "#FFFFFF"
      disabled-text-color: "#666666"
      ### Sidebar Menu ###
      sidebar-icon-color: "#979797"
      sidebar-text-color: "#e3e6e8"
      sidebar-selected-background-color: var(--primary-background-color)
      sidebar-selected-icon-color: "#0337a0"
      sidebar-selected-text-color: var(--sidebar-selected-icon-color)
      ### States and Badges ###
      state-icon-color: "#0337a0"
      state-icon-active-color: "#6dacff"
      state-icon-unavailable-color: var(--disabled-text-color)
      ### Sliders ###
      paper-slider-knob-color: "#0337a0"
      paper-slider-knob-start-color: var(--paper-slider-knob-color)
      paper-slider-pin-color: var(--paper-slider-knob-color)
      paper-slider-active-color: var(--paper-slider-knob-color)
      paper-slider-secondary-color: var(--light-primary-color)
      ### Labels ###
      label-badge-background-color: "#424242"
      label-badge-text-color: "#EAEEF1"
      label-badge-red: "#424242"
      ### Cards ###
      paper-card-background-color: "#1A1A1A"
      paper-listbox-background-color: var(--primary-background-color)
      ### Toggles ###
      paper-toggle-button-checked-button-color: "#0337a0"
      paper-toggle-button-checked-bar-color: "#F36060"
      paper-toggle-button-unchecked-button-color: "#757575"
      paper-toggle-button-unchecked-bar-color: "#424242"
      ### Table row ###
      table-row-background-color: var(--primary-background-color)
      table-row-alternative-background-color: var(--secondary-background-color)
I am using the pmxmononight theme. I’m not sure why the highlighted menu item can’t be seen, i got the same problem on pmxmonolight theme too.
Add these:
sidebar-icon-color: var(--text-primary-color, white)
sidebar-text-color: var(--text-primary-color, white)
sidebar-selected-text-color: white
sidebar-selected-icon-color: white
it works! Thanks a lot
Can you share your harmony hub config please? id like to have an input select lie yours
@reua can you share you harmony remote config please i"d like to have an iput select for my activities but havn’t been able to set it
Just getting started with HA. My plan is to use 3 or 4 Amazon Fire tablets to display HA in various parts of the house. Now basic question. Can I have different themes running on each tablet display. Can this be done?
Great work on the themes that I have seen so far. Thanks everyone for contributing.
Glenn.
You can assign a theme per user. If you made a user for each tablet you could specify the theme for that tablet/user in the user profile page.
I am using this,
I am using binary sensor to detect whether the connected device is on/off and also using ping
With this pmxmono theme I can’t get connection indication.
Please guide, how to do it.
