Hi guys,
I’d like to share an automation for my computer desk lamps and a standing lamp to be controlled via an IKEA Styrbar remote through ZHA. Here I combined many ideas from different topics for my specific need.
While the “building bricks” are taken from different automations and blueprints this automation concentrates more on the hue light color change and has the purpose to share and add room for comments or ideas. ![]()
Big thank you to @epmatt for the blueprint that sparked my idea. Check out his blueprint here: 🎮 ZHA, deCONZ, Zigbee2MQTT - IKEA E2001/E2002 STYRBAR Remote control Universal blueprint - all actions + double click events - control lights, media players and more with Hooks
Setup:
Ikea Styrbar Remote (4 button remote - the square)
3 x Philips hue Play bar named “light.computerlampe1zha”, named “light.computerlampe2zha” and named “light.computerlampe3zha” (will refer only lamp1, 2 & 3)
1 x Philips Centura spot light
1 x light group to combine the Philips lights named (“computerlichter”)
1 x standing lamp (dumb lamp) controlled with on & off through an IKEA smart power plug
Styrbar Remote function:
Pressing up button (short) - Chooses a random hue color for the first (situated left) Philips play bar lamp 1 with full saturation. The next Philips play bar lamp 2 (situated in the center along the Centura spot light) takes the color and adds a value of 60 on the hue color wheel to the already chosen color from lamp1. The same goes for lamp 3 but adding a value of 120 on the color wheel to the initially picked color from lamp 1.
The intention here was to not have 1 color lit up on the computer desk but different colors following each other on the hue color wheel.
Pressing the down button (short) - Switches of the lights on the computer desk
Long press of the previously mentioned buttons dims them.
Left button (short) - Switch on standing lamp behind the computer desk
Right button (short) - Switch off standing lamp behind the computer desk
Automation:
alias: Computertischlampenautomation
initial_state: on
mode: restart
max_exceeded: silent
- platform: event
event_type: zha_event
event_data:
device_id: 0d79028138c4d79de300fd9d591866d3
- variables:
command: "{{ trigger.event.data.command }}"
cluster_id: "{{ trigger.event.data.cluster_id }}"
endpoint_id: "{{ trigger.event.data.endpoint_id }}"
args: "{{ trigger.event.data.args }}"
- choose:
- conditions:
- "{{ command == 'on' }}"
- "{{ cluster_id == 6 }}"
- "{{ endpoint_id == 1 }}"
sequence:
- variables:
current_hue: "{{ (range(90)|random + (state_attr('light.computerlampe1zha', 'hs_color')[0] if state_attr('light.computerlampe1zha', 'hs_color') else 0)) % 360 }}"
- service: light.turn_on
entity_id: light.computerlampe1zha
hs_color:
- "{{ current_hue }}"
- 100
transition: 1
entity_id: light.computerlampe2zha
hs_color:
- "{{ (current_hue + 60) % 360 }}"
- 100
transition: 1
entity_id: light.computerlampe3zha
hs_color:
- "{{ (current_hue + 120) % 360 }}"
- 100
transition: 1
entity_id: light.hue_centura_color_spot_1
hs_color:
- 100
transition: 1
- conditions:
- "{{ command == 'off' }}"
sequence:
- service: light.turn_off
entity_id: light.computerlichter
transition: 1
- conditions:
- "{{ command == 'move_with_on_off' }}"
- "{{ cluster_id == 8 }}"
sequence:
- repeat:
while: []
sequence:
brightness_step: 10
transition: 1
- delay:
milliseconds: 250
- conditions:
- "{{ command == 'move' }}"
sequence:
- repeat:
while: []
sequence:
brightness_step: -10
transition: 1
- delay:
milliseconds: 250
- conditions:
- "{{ command == 'press' }}"
- "{{ cluster_id == 5 }}"
- "{{ args == [257, 13, 0] }}"
sequence:
- service: switch.turn_on
entity_id: switch.stehlampezha
- conditions:
- "{{ args == [256, 13, 0] }}"
sequence:
- service: switch.turn_off
default: []
I’m curious if you’d have some improvement suggestions or other ideas. ![]()
